Worxman Posted December 10, 2017 Share Posted December 10, 2017 How do I design a gambrel main building with a lean to on each side? I figured out how to do the main building, but I can't figure out how to add the lean to's without changing the gambrel roof of the main building. I want the lean to's to be shed style as shown in the attached picture. Wife and I are going to build a barn house on the land we just purchased. Thanks for any help! Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 10, 2017 Share Posted December 10, 2017 How to set up for a gambrel and shed roof is described, each in the "Build Roof Dialog" - "Roof Styles Tab". Then it is a matter of entering the Roof Tab Data directives into each wall setting up the roof pitch directives. Having a good idea of what those pitch values are is the key to getting this done fast. DJP Link to comment Share on other sites More sharing options...
LawB10 Posted December 10, 2017 Share Posted December 10, 2017 Use a second floor for the Gambrel roof, and then lower the ceiling height, turn off auto rebuild roofs and reset the ceiling height to it's default. Link to comment Share on other sites More sharing options...
Worxman Posted December 11, 2017 Author Share Posted December 11, 2017 Thanks for the responses, but I can do the gambrel roof no problem on the center section. My question was how to do the lean to's on each side. I tried changing the roof type to shed on each of the lean to's, but then it changed the main gambrel section. Link to comment Share on other sites More sharing options...
solver Posted December 11, 2017 Share Posted December 11, 2017 Posting images showing your issues will help. On 12/11/2017 at 12:40 AM, Worxman said: but then it changed the main gambrel section. Expand How did it change? No problem doing this. Link to comment Share on other sites More sharing options...
Worxman Posted December 11, 2017 Author Share Posted December 11, 2017 Eric, That is exactly what I'm trying to do, but on both sides. Can you tell me how you added the lean to section? Link to comment Share on other sites More sharing options...
solver Posted December 11, 2017 Share Posted December 11, 2017 Draw the 3 walls, set the end walls to full gable. Build the roof. Link to comment Share on other sites More sharing options...
Worxman Posted December 11, 2017 Author Share Posted December 11, 2017 So I did that. I drew the 4 walls of the main building and set the end walls to full gable and then built the gambrel roof. Then I added the 3 walls for the lean to and tried to set the end walls to full gable and built the shed style roof, but it changed the gambrel roof too. Link to comment Share on other sites More sharing options...
solver Posted December 11, 2017 Share Posted December 11, 2017 On 12/11/2017 at 3:01 AM, Worxman said: but it changed the gambrel roof too. Expand Post screen captures showing what's happening, or post the plan file (make sure it's not open in Suite). Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 11, 2017 Share Posted December 11, 2017 DJP Link to comment Share on other sites More sharing options...
LawB10 Posted December 12, 2017 Share Posted December 12, 2017 Could you upload the plan please Link to comment Share on other sites More sharing options...
LawB10 Posted December 13, 2017 Share Posted December 13, 2017 Is this what you trying to do? I lowered the second floor ceiling to 80", the pitch for the lean to is 4". I turned off auto rebuild roofs and the reset second floor ceiling height to it's default. barnhouse.planFetching info... Link to comment Share on other sites More sharing options...
