Gambrel building with lean to's on each side
Worxman
How do I design a gambrel main building with a lean to on each side? I figured out how to do the main building, but I can't figure out how to add the lean to's without changing the gambrel roof of the main building. I want the lean to's to be shed style as shown in the attached picture. Wife and I are going to build a barn house on the land we just purchased. Thanks for any help!
How to set up for a gambrel and shed roof is described, each in the "Build Roof Dialog" - "Roof Styles Tab". Then it is a matter of entering the Roof Tab Data directives into each wall setting up the roof pitch directives. Having a good idea of what those pitch values are is the key to getting this done fast.
Thanks for the responses, but I can do the gambrel roof no problem on the center section. My question was how to do the lean to's on each side. I tried changing the roof type to shed on each of the lean to's, but then it changed the main gambrel section.
So I did that. I drew the 4 walls of the main building and set the end walls to full gable and then built the gambrel roof. Then I added the 3 walls for the lean to and tried to set the end walls to full gable and built the shed style roof, but it changed the gambrel roof too.
