DesignsbyAndrea Posted April 3, 2017 Share Posted April 3, 2017 I am trying to build a gable roof over one room of my homes design. I have an open living room without a ceiling and then an attached kitchen with the ceiling on it. I don't know how to build a gable roof over a room with one exterior wall and one interior wall. I attached a picture and I need the room that is showing without a ceiling to be a gable ceiling roof and the others with ceilings. I've searched how to's and and I'm not finding what I need. I'm a new user, please help. Link to comment Share on other sites More sharing options...
solver Posted April 3, 2017 Share Posted April 3, 2017 Roof structures do not necessarily reflect the ceilings below. See if these articles help. https://www.homedesignersoftware.com/search/?q=cathedral&default_tab=support Link to comment Share on other sites More sharing options...
LawB10 Posted April 3, 2017 Share Posted April 3, 2017 Have you tried using the break wall tool? Break the wall where you want the gable to be and then click on that wall, check full gable. Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 On 4/3/2017 at 3:21 PM, solver said: Roof structures do not necessarily reflect the ceilings below. See if these articles help. https://www.homedesignersoftware.com/search/?q=cathedral&default_tab=support Expand Here's my problem, I need the one room only to have a gable roof. I created a roof over the house and it doesn't put a gable roof (cathedral ceiling) only over that one room, but the whole house. Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 On 4/4/2017 at 3:14 PM, DesignsbyAndrea said: Here's my problem, I need the one room only to have a gable roof. I created a roof over the house and it doesn't put a gable roof (cathedral ceiling) only over that one room, but the whole house. Expand This is the room I'm trying to create..... Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 On 4/3/2017 at 7:52 PM, LawB10 said: Have you tried using the break wall tool? Break the wall where you want the gable to be and then click on that wall, check full gable. Expand Nothing changed on the roof line when I did that. Link to comment Share on other sites More sharing options...
solver Posted April 4, 2017 Share Posted April 4, 2017 On 4/4/2017 at 3:20 PM, DesignsbyAndrea said: Nothing changed on the roof line when I did that. Expand The program uses the concept of a Room. You control the ceiling above each room by changing settings in the Room Specification dialog. If you want a cathedral ceiling in a specific area, that area needs to be defined as a room. Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 I already have it defined as a room. If I don't have a roof drawn, I can draw a roof over that room but then it messes up because I'm putting the roof on an exterior wall and and interior wall. I guess I need to figure out how to draw a gable roof over one room but have another roof over the whole home. I don't know what the whole homes roof lines look like, just that one room. Should I have a roof generated over the whole house then some how create a cathedral in a gable style over that one room? That's what I'm having trouble doing. Link to comment Share on other sites More sharing options...
solver Posted April 4, 2017 Share Posted April 4, 2017 Are you only concerned with the interior of the house? You need a roof over that single room to create the cathedral? On 4/4/2017 at 4:15 PM, DesignsbyAndrea said: draw a roof over that room but then it messes up because I'm putting the roof on an exterior wall and and interior wall. Expand What "messes up"? What's wrong with what you have? On 4/4/2017 at 4:15 PM, DesignsbyAndrea said: Expand Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 Yes I am mainly concerned with the interior of this room. I am wanting to draw this room an apply beams for a concept design for a client. I want to learn to do it correctly. The way it is now the roof line is protruding through the ceiling in the hallway next to it and there is only a roof over that one room. When I try and shorten the roof it leaves a gap and I'm not sure how to fix that. Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 The roof comes through the ceiling Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 and once i shorted the roof plane to not show the roof line through the hall ceiling, this happens..... I know there has to be a correct way to do this but I'm struggling to fix it. thanks for your help Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 4, 2017 Share Posted April 4, 2017 You have Pro, so use 2 ceiling planes. Link to comment Share on other sites More sharing options...
solver Posted April 4, 2017 Share Posted April 4, 2017 The "correct" way is to model the roof as it is, but in this case, that's not needed. All you need to do is create a roof structure that provides room for the cathedral ceiling below. In the Build Roof Dialog, enter a value in the field indicated. 6" is plenty. This tells the program to raise the roof structure an extra amount, keeping it out of your way. This has no effect on ceiling heights, only the roof. Also make sure the roof pitch is higher than the ceiling pitch. Your ceiling looks like a 3 or 4 pitch, so make sure the roof is greater, like 6 or 8. Make The 3 walls shown Full Gable. Build the roof. In the Build Roof dialog, change the roof pitch to match your ceiling pitch, and draw in 2 ceiling planes. I made 2 videos, but did not change the pitch before drawing the ceiling planes, so the videos show how to do it manually. Next draw in your own ceiling planes. http://screencast-o-matic.com/watch/cbffbj68Gp http://screencast-o-matic.com/watch/cbffbl68m1 Link to comment Share on other sites More sharing options...
LawB10 Posted April 4, 2017 Share Posted April 4, 2017 I think it's time to upload the plan.... Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 ok! Thats helpful! So did you manually draw the roof planes then add the dormer over the window? Link to comment Share on other sites More sharing options...
solver Posted April 4, 2017 Share Posted April 4, 2017 Auto built the roof. Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 On 4/4/2017 at 6:29 PM, solver said: Auto built the roof. Expand ok great this has helped a lot thank you. Link to comment Share on other sites More sharing options...
DesignsbyAndrea Posted April 4, 2017 Author Share Posted April 4, 2017 Ok my next questions is now how do I add two skylights to that roof? Link to comment Share on other sites More sharing options...
solver Posted April 4, 2017 Share Posted April 4, 2017 Skylight tool Link to comment Share on other sites More sharing options...
