jerry8491 Posted January 27, 2017 Share Posted January 27, 2017 If I browse to Home Designer Core Catalogs > Interiors > Accessories > Rugs > Rectangular Rug, I can click on the icon in the Preview Pane, and then click in a room on my floor plan, and a rug is drawn. If, instead, I enter "rugs" in the search bar, I get some additional rugs to show up. If I click on, for example, "Oriental Blue Rug" in the Search Results Pane, the colored, patterned rug shows in the Preview Pane. However, if I click on that rug in the Preview Pane, and try to click on a room area in my floor plan, nothing happens. I get the similar non-behavior for the "Border Rug Green". I even tried this with a new plan, drawing exterior walls, then interior walls; I got the same behavior. Is there something special about those search results? If so, how do I take advantage of the rug types shown? Oriental Blue Rug.pdf Border Rug Green.pdf Link to comment Share on other sites More sharing options...
DCortes Posted January 27, 2017 Share Posted January 27, 2017 It is to my understanding that those that you see when under RUGS its like a wall to wall paint job. If you do a camera view and select a room and then click on that oriental rug you will see your cursor change over to a spray can. If you then click on that floor while still in camera view you will see it paint the whole floor as that rug you chose under RUGS. 1 Link to comment Share on other sites More sharing options...
solver Posted January 27, 2017 Share Posted January 27, 2017 If you will search this forum, you will find at least one post explaining rugs. I imagine there is also a Knowledge Base article. Link to comment Share on other sites More sharing options...
LawB10 Posted January 27, 2017 Share Posted January 27, 2017 Use the one in Interiors and then use the one in materials to change the look of the rug. 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted January 30, 2017 Share Posted January 30, 2017 KB-00290: Placing and Modifying a Rug 2 Link to comment Share on other sites More sharing options...
jerry8491 Posted January 31, 2017 Author Share Posted January 31, 2017 All, thanks for the help! Link to comment Share on other sites More sharing options...
