MatE Posted November 19, 2015 Share Posted November 19, 2015 I has trying to export a simple model, but the DXF option looses all the 3D data? It is only Flat? This is the only program I use that looses the 3D Data, is there something I need to "Fix?". Link to comment Share on other sites More sharing options...
solver Posted November 19, 2015 Share Posted November 19, 2015 I'd ask Tech Support. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 19, 2015 Share Posted November 19, 2015 I checked Home Designer Pro 2015 and it will export 3D STL files (I am not sure about Home Designer Pro 2016, it is on my laptop). Chief Architect Premier does export to several popular 3D file formats (colada, 3D dwg, obj, 3DS, stl, skp) but Home Designer Pro is more limited in ranges of choices of export file formats.) What version of Home Designer Pro do you have? DJP Link to comment Share on other sites More sharing options...
MatE Posted November 19, 2015 Author Share Posted November 19, 2015 I have Home Designer Pro 2016. I can see many useful things I could do If I can figure out some form of a 3D export of the forms created with HD Pro, Even if I loose all intelligent data and it's just one combined shape. I thought the DXF export would retain the 3D info? Like other program exports do? Thanks for your reply! Link to comment Share on other sites More sharing options...
MatE Posted November 23, 2015 Author Share Posted November 23, 2015 OK I found the "trick?". My goal was to mix an existing part of a house with the remodel part. But only get a cut list for the remodel part... Here is a newby solution that might work, haven't finished testing... Create the existing Bldg. 1 - Export existing Bldg. as an .slt file > import into Sketchup > Erase all extra stuff > save 2 - Import this back into HD Pro. (It's just a block now - Haven't tested coloring it) 3 - Draw new remodel data and put it up to the imported block? 4 - ? parts output now only lists the new remodel portion? Pretty crude.... But it might work? Still a lot of playing to do? Link to comment Share on other sites More sharing options...
MatE Posted November 23, 2015 Author Share Posted November 23, 2015 Thanks David, you sent me down the right road! Link to comment Share on other sites More sharing options...
katalyst777 Posted November 23, 2015 Share Posted November 23, 2015 Is the option to import an STL in to SketchUp only available in the paid version? I don't see it as an option in the free version of SketchUp Make that I have. Link to comment Share on other sites More sharing options...
Solution MatE Posted November 24, 2015 Author Solution Share Posted November 24, 2015 Nope... Its a Ruby you just add to your existing set that you can get at Sketchup or Sketchucation. Link to comment Share on other sites More sharing options...
RethinkingGreen Posted August 28, 2016 Share Posted August 28, 2016 I checked Home Designer Pro 2015 and it will export 3D STL files (I am not sure about Home Designer Pro 2016, it is on my laptop). Chief Architect Premier does export to several popular 3D file formats (colada, 3D dwg, obj, 3DS, stl, skp) but Home Designer Pro is more limited in ranges of choices of export file formats.) What version of Home Designer Pro do you have? DJP My HDP Pro 2016 shows STL as an option in the export dialog, but it is grayed out. What do I need to do to export to it? Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 28, 2016 Share Posted August 28, 2016 You might want to search the Knowledge base of help articles for more data, I found this article about .stl files, there are others: https://hometalk.chi...fix-the-models/ DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted August 29, 2016 Share Posted August 29, 2016 My HDP Pro 2016 shows STL as an option in the export dialog, but it is grayed out. What do I need to do to export to it? You need to be in a 3D Camera view. 1 Link to comment Share on other sites More sharing options...
