Vman888 Posted June 30, 2015 Share Posted June 30, 2015 Hi everyone, I had a look around on google and forums but couldn't exactly find a way to build brick-built stair cases in Home Designer Suite 2016. Is there a trick? The wooden stairs that are standard supplied fit with very few home designs IMO. Especially for exterior applications. Would very much appreciate any tips and hints on how to approach this. Thanks much Vman Example http://t2.gstatic.com/images?q=tbn:ANd9GcSlwVm_vkgyvvp37qpWzzrXmcFXv0kHHoRlNv2MbotM17Sy71uQHw Link to comment Share on other sites More sharing options...
Kbird1 Posted June 30, 2015 Share Posted June 30, 2015 do you want brick stairs or semi circular brick stairs ? two different animals especially in Suite. if you change all the staircase materials ---- tread/riser/support wall to brick and uncheck open riser and open underneath, you will have a Brick stair , or concrete ,or whatever material you choose ..tile etc. M. Link to comment Share on other sites More sharing options...
solver Posted June 30, 2015 Share Posted June 30, 2015 You may manually create your steps. Use whatever tools your software has to make boxes covered with brick. Link to comment Share on other sites More sharing options...
Vman888 Posted June 30, 2015 Author Share Posted June 30, 2015 OK great, many thanks, I understand. This if for straight stairs. I need the railing. How would I be able to make the railing into a solid brick railing? Link to comment Share on other sites More sharing options...
Vman888 Posted July 12, 2015 Author Share Posted July 12, 2015 Hi all, I'm finally back on my project. Was wondering if anyone knew how to make the railing into a solid low height wall. I tried experimenting with glass panels but I couldn't figure out how to put solid walls. Any help much appreciated. Rgds Link to comment Share on other sites More sharing options...
solver Posted July 12, 2015 Share Posted July 12, 2015 You will find a variety of shapes in the library -- Wedge, Boxes etc. Combine these as needed to create the shape you need. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 12, 2015 Share Posted July 12, 2015 Do you have straight railings in Suite?it is possible, just not sure if Suite can do it ? I used straight Railings in the Pic but if you don't have them try Solid Railings and change the material for the interior and exterior wall to brick and the rail if possible . Link to comment Share on other sites More sharing options...
LawB10 Posted July 13, 2015 Share Posted July 13, 2015 Vman, First build you're stairs, in the style specification box uncheck everything and change the overhang to 0 In the railing specifation box uncheck railing on: both left and right. Click on the wall tool and choose the half wall tool and make a room, making sure the stairs are touching the walls and add a doorway. Make the room larger than the stairs and edit, uncheck the roof and ceiling box, you may have too adjust floor© to -10 or lower Open Moldings, uncheck the default and delete the base and crown moldings. Click OK and readjust the walls back to the stairs Open the materials library and go for it. If the stairs are not touching the walls, the walls won't follow the stairs. If you use the rail tool, the rail won't follow the stairs. The attached examples are with and without a landing. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 13, 2015 Share Posted July 13, 2015 if you use rails they will follow the Stairs if you check the box "follow stairs", it how I did it above but once again not sure if that is in Suite though. M. Link to comment Share on other sites More sharing options...
LawB10 Posted July 14, 2015 Share Posted July 14, 2015 Kbird, Suite doesn't have that option. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 14, 2015 Share Posted July 14, 2015 Thx , no word back from VMan , but the info may help future Readers who have other titles. Link to comment Share on other sites More sharing options...
Jo_Ann Posted July 14, 2015 Share Posted July 14, 2015 This older post might help. https://hometalk.chiefarchitect.com/index.php?/topic/538-stair-with-landing-and-solid-rail/?hl=%2Bstair+%2Brailing Link to comment Share on other sites More sharing options...
jeromecorey Posted February 15, 2016 Share Posted February 15, 2016 Good work Jo_Ann i am looking for that kind of information and kbird said right the info may help future Readers and here it helped me. Thank God solved my prob 60%. Link to comment Share on other sites More sharing options...
jeromecorey Posted May 9, 2016 Share Posted May 9, 2016 Yes its helpful for the future reader too. Link to comment Share on other sites More sharing options...
