FlightDeck
Countertops not stopping at partitions
Hi folks, encountered an issue today with countertops crashing through cabinet partitions (and adjacent appliances).  For example the one shown in the image shows the countertop with 2-inch overhang sticking through the adjacent partition and into the refrigerator.
I haven't noticed this issue before and recall the countertops always stopping nicely at partitions.
Any ideas what is causing this?
Thanks and regards,
KDJ
If I remember correctly, I always need to turn off side overhangs, or this happens, and testing just now confirms this.
Thanks, Eric.  I had to do the same.  And in cases where that wasn't appropriate, I had to use the custom countertop feature instead.  I checked some earlier models I made and it seems the countertop never stops at the partition.  I hadn't noticed before because my overhangs were smaller.
KDJ
The command is found in the Base cabinet Specification dialog - "Flat Sides"
Thanks, David.  Unfortunately it does both sides so if it's also an end cabinet you lose the needed overhang.  I used a custom countertop instead.  I'm just surprised that the software doesn't automatically clip countertops at partitions given how smartly it seems to handle other situations.
