Designer_Ryan Posted November 21, 2024 Share Posted November 21, 2024 Every time I split the plant shelf room, the wall in the middle extends through. I have selected each room, one for the fridge, and the other for the pantry, and lowered the ceiling on both. What could I do to prevent the middle wall from extruding through the top, automatically, every time? I've added the drawing file for you to view. Thanks. Plan.plan Link to comment Share on other sites More sharing options...
Rookie65 Posted November 21, 2024 Share Posted November 21, 2024 While I don't open .plan files that people post, have you thought of making that wall a solid railing and setting the railing height to what the other rooms are? And again, you would likely benefit from spending a lot of time with the reference manual to understand the program better. Link to comment Share on other sites More sharing options...
solver Posted November 21, 2024 Share Posted November 21, 2024 Pro 2024 doesn't have the problem. The Shelf Ceiling feature when first introduced was somewhat buggy. If you are using the software in a business, I'll suggest you stay current. One of the rather stupid policies of Chief Architect is they sometimes fix problems in new versions, but don't update older ones. Link to comment Share on other sites More sharing options...
Rookie65 Posted November 21, 2024 Share Posted November 21, 2024 Or the "fixes" create problems that never existed before Link to comment Share on other sites More sharing options...
Designer_Ryan Posted November 21, 2024 Author Share Posted November 21, 2024 (edited) 28 minutes ago, Rookie65 said: While I don't open .plan files that people post, have you thought of making that wall a solid railing and setting the railing height to what the other rooms are? And again, you would likely benefit from spending a lot of time with the reference manual to understand the program better. Rookie65, I have tried the solid railing, but after getting it to the correct height, and changing the top of the railing to drywall, the top of the plant shelf, at times have not been solid. You can see the difference where the railing is. Here's a pic of what happens when I use railing. I also, still have the sides extruded. Edited November 21, 2024 by Designer_Ryan Link to comment Share on other sites More sharing options...
Designer_Ryan Posted November 21, 2024 Author Share Posted November 21, 2024 The top is noticeable when the standard 2x4 wall is lowered, by pulling it down, in 3D mode. Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 22, 2024 Share Posted November 22, 2024 It's kind of unclear what you really want. Is it something like this, or a level shelf top across the entire unit? Link to comment Share on other sites More sharing options...
Designer_Ryan Posted November 22, 2024 Author Share Posted November 22, 2024 27 minutes ago, Jo_Ann said: It's kind of unclear what you really want. Is it something like this, or a level shelf top across the entire unit? Level Link to comment Share on other sites More sharing options...
Jo_Ann Posted November 22, 2024 Share Posted November 22, 2024 It's pretty simple. Open the pantry "room", set it as shelf ceiling, then set it's finished ceiling height. Open the refrigerator "room", set as shelf ceiling, then set the ceiling height the same as the pantry room. Link to comment Share on other sites More sharing options...
