dantappin Posted October 18, 2024 Share Posted October 18, 2024 2025 Pro - Mac I have searched in here and the online manuals etc. I am failing to understand how you can set default prices for materials. For example basic materials like 4x8 drywall, OSB, studs, concrete. I get that you can create a materials list and manually updater unit costs. Is this not possible in the software? If so this is a huge failing. The online guide explains the procedure to update individual walls and then set prices. This then only updates the list for this items. I tried "updating to master list" that doesn't seem to anything. Changing prices in there has no effect. I want to run the material list for the whole house and see the updates as I make changes etc. Seems crazy to have to manually enter 200-300 lines of material costs each time. Dan Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 18, 2024 Share Posted October 18, 2024 "Edit - Preferences - Edit - Materials" DJP Link to comment Share on other sites More sharing options...
solver Posted October 18, 2024 Share Posted October 18, 2024 12 hours ago, dantappin said: I tried "updating to master list" that doesn't seem to anything. Changing prices in there has no effect. Revisit the documentation on the Materials List / Master List. The process is not very intuitive, but it does work. Link to comment Share on other sites More sharing options...
dantappin Posted October 19, 2024 Author Share Posted October 19, 2024 14 hours ago, DavidJPotter said: "Edit - Preferences - Edit - Materials" DJP Hmmm... nope. Closest thing is 'Default Settings'. No where in any pane where you can set a default price for an material etc. Link to comment Share on other sites More sharing options...
dantappin Posted October 19, 2024 Author Share Posted October 19, 2024 14 hours ago, solver said: Revisit the documentation on the Materials List / Master List. The process is not very intuitive, but it does work. Finally figured it out. Wow you are right not intuitive at all: Generate a material list Select line items you want to save Click 'Update to Master List' Edit master list with prices Go back to your material list - select the lines to update Click 'Update from Master List' Why can't the generation of a materials list automatically pull from the master list by default? 1 Link to comment Share on other sites More sharing options...
y-g-m-n Posted October 19, 2024 Share Posted October 19, 2024 wow your menus are different then my Windows PRo. I mean You have emojis whats up with that? Link to comment Share on other sites More sharing options...
dantappin Posted October 20, 2024 Author Share Posted October 20, 2024 All goes well until your entire master list gets deleted after a crash! Link to comment Share on other sites More sharing options...
dantappin Posted October 20, 2024 Author Share Posted October 20, 2024 16 hours ago, y-g-m-n said: wow your menus are different then my Windows PRo. I mean You have emojis whats up with that? On a mac the preferences are in the Applications menu. Link to comment Share on other sites More sharing options...
MStory63 Posted February 19, 2025 Share Posted February 19, 2025 Agreed, it is not intuitive at all. But once I've done that work, is there any way to share the Master List with others on my team? Or do they have to go through the same process? Thanks. Link to comment Share on other sites More sharing options...
