TCWorley Posted 11 hours ago Share Posted 11 hours ago I'm taking a class and the instructor is allowing me to use Home Designer Suite rather than AutoCad. She wants me to show a furred wall in the basement, and I cannot figure out a way to do that. Is this something possible in the Suite version? Do I create an interior wall and change the spec's to essentially be a skinny floating wall? Link to comment Share on other sites More sharing options...
Rookie65 Posted 6 hours ago Share Posted 6 hours ago I don't know all of Suite's limitations, yet depending on which way the furring is going to run, you could likely do it with soffits, or custom backsplashes. Put the 1st one where it needs to be against the wall and then define the size (likely 1"x3"). Then "transform/replicate" the right dimension in the right direction. Make the material fir framing so it looks like wood. Link to comment Share on other sites More sharing options...
solver Posted 4 hours ago Share Posted 4 hours ago 6 hours ago, TCWorley said: I'm taking a class and the instructor is allowing me to use Home Designer Suite rather than AutoCad What sort of class? Suite is in no way comparable to AutoCAD, and especially so for someone who doesn't really know Suite. If you understand what is being asked for, then using the tools in Suite to emulate a furred wall should be obvious. I believe Keith is suggesting how to add furring strips to a wall, I suspect you are asking about something different. Link to comment Share on other sites More sharing options...
