Designer_Ryan Posted October 14, 2024 Share Posted October 14, 2024 I'm using soffits to make a tray ceiling. On the right of the room the soffits join and you don't see middle lines, but the 30 degree walls, on the left, the soffits show all the lines. Can these be joined somehow, so it looks like one solid tray ceiling all the way around? Tray Ceiling.planFetching info... Link to comment Share on other sites More sharing options...
Rookie65 Posted October 14, 2024 Share Posted October 14, 2024 If the ceilings are different heights, try using room dividers to enclose the higher ceiling room and change the height of the new room Link to comment Share on other sites More sharing options...
Designer_Ryan Posted October 14, 2024 Author Share Posted October 14, 2024 It's all one room, ceiling height 10'. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 14, 2024 Share Posted October 14, 2024 Then how do you have a tray ceiling, as they are usually a different height? Link to comment Share on other sites More sharing options...
solver Posted October 15, 2024 Share Posted October 15, 2024 On 10/14/2024 at 10:03 PM, Designer_Ryan said: I'm using soffits to make a tray ceiling. Expand Try using a Slab, or Slabs instead of a Soffit. Slabs and other objects like Custom Countertops (which would also work, especially if you need moldings), have a Line Style that you may set to blank. Use CAD to outline the tray. Link to comment Share on other sites More sharing options...
y-g-m-n Posted October 15, 2024 Share Posted October 15, 2024 On 10/14/2024 at 10:15 PM, Rookie65 said: If the ceilings are different heights, try using room dividers to enclose the higher ceiling room and change the height of the new room Expand This is how I do it. You draw the inner edge of tray ceiling with the room divider line (under BUILD). This creates 2 rooms - The larger inside tray room - Click on this room and ensure ceiling set to your 10ft. Then the outer "ring" room is your lower ceiling height room - Click on it and in structure tab set ceiling height to whatever you want that is less then 10ft be it 9ft or 8ft-10" but basically the height would be your 10ft ceiling less the vertical dim of this tray. Crown molding works in either room so you can insert crown inside tray and not on outside or both have crown or only th shorter outside area has crown. Play with it. Hell I made it once out of wall cabinet once I just turned into boxes Many ways to make tray ceiling and depends on framing crew as such there are many ways to draw them. As for the lines you see using soffits that is just freak of software in that in plan view it does not "JOIN" the soffit to remove those lines. Nothing to worry about in 3d views nor plan. If you want it better Join the soffits at the inside corners not the outside wall corners as it may look better to you that way. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 15, 2024 Share Posted October 15, 2024 We all have our way to do things. Link to comment Share on other sites More sharing options...
Designer_Ryan Posted October 15, 2024 Author Share Posted October 15, 2024 (edited) Thanks everyone for your help. When I started two years ago, I've read that you can't make tray ceilings in HDPro, that's how I got the soffit idea. y-g-m-n, I'll give this a try. Rookie65, I'll try the different ceiling heights. Two different ceiling heights worked. Thanks again. Edited October 15, 2024 by Designer_Ryan Tried; added pic. Link to comment Share on other sites More sharing options...
y-g-m-n Posted October 16, 2024 Share Posted October 16, 2024 no add some crown inside the tray for a fancy look. Link to comment Share on other sites More sharing options...
