Txcustom Posted August 19, 2024 Share Posted August 19, 2024 Hello all, I noticed when looking at the structure of my wall, the brick ledge appears to be at least 12" below the floor height. The concrete crew uses a 2x6 when pouring, so just need a 1.5" ledge. Does anyone have a good pointer to fixing this? Thanks in advance Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 19, 2024 Share Posted August 19, 2024 Witch application and version do you have? DJP Link to comment Share on other sites More sharing options...
solver Posted August 19, 2024 Share Posted August 19, 2024 Always give your title (Pro, Suite) and year (2024, 2025). None of the Home Designer products let you specify brick ledge dimensions directly. Your image seems to show a wood floor structure over a basement or crawlspace. showing a cross section like this would help. Link to comment Share on other sites More sharing options...
Txcustom Posted August 19, 2024 Author Share Posted August 19, 2024 12 minutes ago, solver said: Always give your title (Pro, Suite) and year (2024, 2025). None of the Home Designer products let you specify brick ledge dimensions directly. Your image seems to show a wood floor structure over a basement or crawlspace. showing a cross section like this would help. Sorry, I have Home Designer Pro 2024 Link to comment Share on other sites More sharing options...
Txcustom Posted August 19, 2024 Author Share Posted August 19, 2024 24 minutes ago, DavidJPotter said: Witch application and version do you have? DJP Sorry, I have Home Designer Pro 2024 Link to comment Share on other sites More sharing options...
y-g-m-n Posted August 20, 2024 Share Posted August 20, 2024 yeah it sucks HD users cannot adjust brick ledge for depth and width as it can dictate patio and porch slab heights Link to comment Share on other sites More sharing options...
