Can I change cabinet doors to traditional overlay in Home Designer Architectural 2021?
DB4570
Can I change cabinet doors and drawer fronts to traditional overlay in Home Designer Architectural 2021? I have looked at the different styles in the library and it seems they are all full-overlay.
Thanks
I know in PRO you an as it is done inside cabinet edit window not by certain door.
Door & drawer size vary depending on how you hve cabinet set up.
so I think it is on second tab and you select FRAME or FRAMELESS.
then inset door or overlay or full overlay.
With a value for actual overlay and face frame width.
If confused look at help screen for cabinets or I am sure they have videos.
If you have already chosen the template style for your  plan...
Look In the library,
Architectural > Cabinets > Style Template Cabinets.
There are  8 styles there.
Carefully look at each style, as they are all slightly different from each other.
