BeginnerMorle Posted May 23, 2024 Share Posted May 23, 2024 Hello everyone, Suppose I have two separate objects (see the picture below). Is it possible to combine them into one object? Thanks in advance. Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 23, 2024 Share Posted May 23, 2024 try selecting both and then hitting the ARCHITECHURAL BLOCK button. It will then combine but you lose the edit screen for each so make sure they are located where yo want them. Also use the HELP screen with this command. Link to comment Share on other sites More sharing options...
Jo_Ann Posted May 23, 2024 Share Posted May 23, 2024 "It will then combine but you lose the edit screen for each". Not true. Click on the block part you want to edit, and hit TAB until the selected part shows edit handles. CTRL+E will then open that part to be edited. Link to comment Share on other sites More sharing options...
BeginnerMorle Posted May 23, 2024 Author Share Posted May 23, 2024 @y-g-m-n thanks a lot for you support. I can not find this "Architectural Blocks" tool in my toolbar do you now why? @Jo_Ann: I will check this later. thanks a lot Link to comment Share on other sites More sharing options...
solver Posted May 23, 2024 Share Posted May 23, 2024 12 hours ago, BeginnerMorle said: Is it possible to combine them into one object? Not really. When asking this type of question, it's important to say what you have done to create what is shown. What type of objects are you using, and what are you using them to represent? The Chief Architect products have Boolean operations -- Subtraction, Union and Intersection, and the object types that will respond to them. Home Designer does not. The best you can do in Home Designer is to create an Architectural Block as others have suggested, but not all things may be blocked together, which is why that tool in not available. If you know SketchUp or a similar program, you can create objects there and import. Link to comment Share on other sites More sharing options...
y-g-m-n Posted May 24, 2024 Share Posted May 24, 2024 15 hours ago, Jo_Ann said: ... Click on the block part you want to edit, and hit TAB until the selected part shows edit handles. CTRL+E will then open that part to be edited. cool I learned something - lot of steps to get there but cool - I hope I remember I used to just explode - edit - re-block together. Link to comment Share on other sites More sharing options...
