447Debbie Posted April 11, 2024 Share Posted April 11, 2024 When I put a door in here, to me it looks like it needs something to attach to inside those red rectangles. Can someone show me the correct way to draw this? It's a 36" gate between two concrete walls, one parallel to the gage, one perpendicular to the gate. Link to comment Share on other sites More sharing options...
Robborito Posted April 12, 2024 Share Posted April 12, 2024 16 hours ago, 447Debbie said: it needs something to attach to inside those red rectangles Indeed it should. Universally speaking, as I am in Australia and not the US. But you are correct. It depends on how you placed the gate. I would insert the gate like a door is inserted. That would show the jambs that are missing. See whoever else comments closer to home for you. 1 Link to comment Share on other sites More sharing options...
y-g-m-n Posted April 13, 2024 Share Posted April 13, 2024 It depends on gate design and hardware chosen for latch. If latch sticks out past door the it would hit that wallprior to closing so you would narrow gate width and maybe add a block behind the latch catch on wall. I have seen it done many ways and all depends on hardware. Now in HD would add jamb made from 2x4 pressure treated. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 13, 2024 Share Posted April 13, 2024 Try drawing a railing at the height of your gate in that area. Depending on the material needed to be used, you can make the railing solid, panel, balusters, etc. Then add your gate to the railing just put in there. Depending on the blocking you want to mount it on, likely a 2x PT, deduct 3" from the total width for your gate size and center it in the railing. Link to comment Share on other sites More sharing options...
