VisionNet Posted December 15, 2023 Share Posted December 15, 2023 I need a “half column” or what we call a pilaster on an exterior wall Can’t find any in the object millwork catalogs Any way I can “explode” an existing Doric column object so I can lay it flat against an exterior wall? thoughts? Link to comment Share on other sites More sharing options...
solver Posted December 15, 2023 Share Posted December 15, 2023 You are asking about an engaged column -- a pilaster is rectangular. Depending on size, you can imbed the symbol in the wall so only part shows. Google 3d warehouse for more symbols. Link to comment Share on other sites More sharing options...
y-g-m-n Posted December 15, 2023 Share Posted December 15, 2023 If part of a railing wall and you use these columns for the posts then you can select HALF POST at ends. Link to comment Share on other sites More sharing options...
VisionNet Posted December 15, 2023 Author Share Posted December 15, 2023 Thank you both for your input (I need engaged columns and pilasters) Tried to push it into the wall, but won’t let me break plane I’ll try to import 3d objects from outside resource Link to comment Share on other sites More sharing options...
Rookie65 Posted December 15, 2023 Share Posted December 15, 2023 it may not let you push it into the wall, yet if you "transform/replicate" it the dimension you need, that often works. It kind of bypasses the default Link to comment Share on other sites More sharing options...
y-g-m-n Posted December 16, 2023 Share Posted December 16, 2023 TURN BUMPING off....that might be what is preventing you from shoving it into wall. Link to comment Share on other sites More sharing options...
