Rotate countertop materials ?
BACLLC
I use HOME DESIGNER PRO 2021, running Windows 10. My question is this (see attached pictures):
I want to rotate the materials on the countertops (shown to the right) so they run in line with the cabinets (image #1). I have saved the cabinets to my "user catalogue", which from what I've researched (see attached images #3 & #4) will then allow me to "rotate" those materials. However when I open the cabinet (my user item) and click on materials I don't see the "rotate" check box in my version of the program (image #2), what is my program missing here ?
Also see how when the cabinets' are placed on different walls (90 degrees of rotation) the countertop then has rotated automatically . . . I am missing something here but not sure what.
Thank you to both Solver and David for your time.
However, I've tried both solutions but having trouble with both of these ideas.
I have renamed and saved certain cabinets (as per Solver) to my User catalogue. This did not work for me.
As I change the degrees as David mentioned in his video it affects "all" cabinets with similar countertop materials (images 1 & 2). So I was still struggling with changing one set of cabinet's and not all of them being affected by that change.
So my solution, however rudimentary, is that I changed the material tone slightly (image #3) and then used the adjust material definition and Wala ! it worked.
I saw that there were two choices (image #4) for material layout (horizontal & vertical) but that did not work either.
Also, why would my program (HD Pro 2021) not have the choice as mentioned above for "rotate angle" on define materials ?
I hope my workaround helps others.
Look at the image -- it's a 2017 version of the program. Things change.
Your program has the same ability -- look at the Offset and Angle section.
My image above showed materials in the library, not cabinets. You need two materials -- one rotated 90 degrees.
No workaround needed.
