Can't select 2nd floor space
DaveFite
I created a 2nd floor after getting my roof planes in the correct position (I want to make the attic into 2nd floor).  I created a closed box with exterior walls.  I attempted to select the new space so I could name it and play with ceiling heights but I can't select the room/space.
What am I doing wrong???  Help?
p1.plan
2015 titles have a feature that shows where bad wall connections are (there should be a "circle" where your bad wall junctions are and you should have a "circle" attached to your cursor until they are fixed (by you). This feature can be turned off but is on by default unless you changed that setting ( Edit - Preferences - Architectural - Wall - Circle Unconnected Wall Ends). so if you turned that off, it is harder to find bad wall connections.
If that is not "it" then posting a copy of your plan will help us help you.
Your wall on the left is an attic wall.
Uncheck 'no room definition' and 'no locate'.
As above I would also uncheck Attic Wall , as they are auto generated and why you see a strange wall connection at each end.
Next time draw ALL 4 walls yourself, to make the Attic (2nd) Level , drawing over the auto generated walls if needed ,this turns them into "normal" walls as, as you can see Attic Walls wont allow Rooms to be built. By default HD does not allow Rooms in any "Attic" Space.
PS I saw your post on CT about the Dormer
