paintitblack Posted March 18, 2022 Share Posted March 18, 2022 id like to paint one side of a door way a different color then the other side. I thought it would be an easy eyedropper situation. Even when I open up the door way and go in materials it only has one spot for door trim as if they have to match always. any suggestions? Link to comment Share on other sites More sharing options...
solver Posted March 18, 2022 Share Posted March 18, 2022 3 hours ago, paintitblack said: any suggestions? Open the doorway, look at the General panel. Link to comment Share on other sites More sharing options...
paintitblack Posted March 18, 2022 Author Share Posted March 18, 2022 I have changed it in there and they still remain matching Link to comment Share on other sites More sharing options...
barthmv Posted March 18, 2022 Share Posted March 18, 2022 I have fooled around with this a little bit because it should be something doable. Often the outside of a door trim is different than the inside. The materials give you the option to modify the exterior and interior but they both change when changing either one. It does't seem to be able to be done in this program. It does let you change the inside and outside of the door to different colors but not the trim. Should be something that support can address and fix. Link to comment Share on other sites More sharing options...
solver Posted March 18, 2022 Share Posted March 18, 2022 3 hours ago, solver said: Open the doorway, look at the General panel. Link to comment Share on other sites More sharing options...
Rookie65 Posted March 18, 2022 Share Posted March 18, 2022 With Pro, you can open the door, check the "separate trim and materials on each side" box and change the door and casing colors there. The trim, or jamb, will be changed to whatever material color the exterior is. Hope that helps? Link to comment Share on other sites More sharing options...
paintitblack Posted March 18, 2022 Author Share Posted March 18, 2022 I have tried countless times in the general panel. there is an option to change the color of either side but when you return to the door it remains matching. I can change the jamb but that's it. Link to comment Share on other sites More sharing options...
paintitblack Posted March 18, 2022 Author Share Posted March 18, 2022 interior trim is just the jamb. Link to comment Share on other sites More sharing options...
solver Posted March 18, 2022 Share Posted March 18, 2022 Link to comment Share on other sites More sharing options...
paintitblack Posted March 18, 2022 Author Share Posted March 18, 2022 ha that did it separate trim. didn't even notice it on the bottom there. thank you. Link to comment Share on other sites More sharing options...
barthmv Posted March 18, 2022 Share Posted March 18, 2022 my previous post on this stated that I didn't think it was doable but after checking out exactly what Solver was saying I found out it works perfectly. You can change both the trim and door to be different on the exterior and the interior just like Solver was saying. Sorry about my previous post being inaccurate. Link to comment Share on other sites More sharing options...
