Mifala Posted February 10, 2022 Share Posted February 10, 2022 I have loaded Home Designer 2020 X11 onto a new computer. It has an 11th Gen Intel(R) Core(TM) i7-1165G7 processor and Intel Iris XE graphics card which your website says is fine to run the program. The program was working fine and then I had to reset the computer with a clean reinstall because of a problem with a different program. When I reloaded Home Designer the 3D rendering is dark to black. If I zoom in close you can start to see the correct colors and material. I have attached some jpegs of the problem. The catalog colors and some other materials have no texture when I go into Define Material. Would appreciate it if anyone can help me with this problem. Thanks Link to comment Share on other sites More sharing options...
solver Posted February 11, 2022 Share Posted February 11, 2022 Have you updated your video card driver? Link to comment Share on other sites More sharing options...
caf200 Posted February 11, 2022 Share Posted February 11, 2022 On 2/10/2022 at 5:50 PM, Mifala said: I have loaded Home Designer 2020 X11 onto a new computer. It has an 11th Gen Intel(R) Core(TM) i7-1165G7 processor and Intel Iris XE graphics card which your website says is fine to run the program. The program was working fine and then I had to reset the computer with a clean reinstall because of a problem with a different program. When I reloaded Home Designer the 3D rendering is dark to black. Update: SOLUTION / SOLVED in my February 11 post below. I am having the seemingly same problem. Perhaps our comparisons can help each others and give others tips to helps us solve them. Positive news to me that in your case: "program was working fine" at one point on that processor/graphics_chipset. Added some pictures from my situation as well as a comparison of our chipsets. I just got a new computer with the same graphics chip. I've done a fair amount of searching on the CA/HD sites and help but haven't figured it out. The plan I'm displaying was created on my other computer using the same Home Designer Pro 2021 (22.3.0.55x64 8-Jun-2020). All same catalogs downloaded and refreshed via HD option. I did notice a few things like the wood color/file did not display correctly on this 2nd PC but I reapplied the exact same thing and it redisplayed the camera and it was OK. My PC (my sig): Intel(R) i7-1185G7 4-Core (11th Gen) 3.0 GHz (4.8 max) | 16GB of LPDDR4x RAM | Integrated Intel Iris Xe Graphics a) I installed my latest graphics drivers from here: https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html b) I installed my latest other drivers from here: https://www.intel.com/content/www/us/en/support/detect.html c) I explicitly created a Windows Restore Point before I installed latest drivers. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 11, 2022 Share Posted February 11, 2022 Like Eric said, update your video card drivers then if no joy, contact Chief Architect Tech Support for help. DJP 1 Link to comment Share on other sites More sharing options...
caf200 Posted February 11, 2022 Share Posted February 11, 2022 SOLUTION / SOLVED Mifala, I opened a support ticket and their response worked for me. HTH Quote We have seen behavior like this with the Intel Iris Xe Graphics but we do have a way to work around this.1. Go to Edit>Preferences2. Go to the Render panel3. Check the box for Texture Compression and click OK. I looked up that option in the help (Index tab and render search word) and here is what it said. Quote When Texture Compression is checked, material textures are compressed so that less video memory is required when a 3D view is generated. Texture Compression takes time, however, so view generation will typically be slower. Link to comment Share on other sites More sharing options...
slynndesign Posted May 3, 2023 Share Posted May 3, 2023 This same issue is happening to me regularly. If I close out of my file and reopen it sometimes will correct itself. I'm not seeing the option you mentioned above for texture compression. Is this a ray tracing option? I'm on x15. On a mac studio m1 chip 2022 without a dedicated graphics card. Wondering if that is the problem too? Link to comment Share on other sites More sharing options...
