Rock Facing around Windows
AQSCI10
Hi was wondering if Home Designer Pro has the capability to shape exterior wall coverings as shown below. I want to extend the rock facing up and over the 3 windows in an arch shape as crudely illustrated below. Or is this only available in a higher version..
Thanks
Thanks. It appears that the custom backsplash function is grayed out in Home Designer Pro 2021 (at least mine) so i assume this is for a higher level version?
That's because you are in plan view.
Right you are, in wrong mode. Worked great. After all that I'm not sure I like the look of it though! But know how to do it now so thanks again.
