dgallagher Posted February 5, 2015 Share Posted February 5, 2015 I am currently attempting to add a breakfast nook to a plan I am working on ad it is not allowing me to run the roof into the wall it is constantly trying to attach it to the roof line that is a storey above. I am going from a family room/kitchen area that has a high ceiling into a nook that would have a standard height ceiling. Very frustrating!!! Link to comment Share on other sites More sharing options...
scottharris Posted February 5, 2015 Share Posted February 5, 2015 Can you post the plan so we can see what you are trying to do? And, what product & version you are using. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 5, 2015 Share Posted February 5, 2015 Learning is frustrating for one and all. Read over these important posts to help get you orientated here and to make more efficient your experience here: http://hometalk.homedesignersoftware.com/forumdisplay.php?2-Q-amp-A DJP Link to comment Share on other sites More sharing options...
dgallagher Posted February 8, 2015 Author Share Posted February 8, 2015 Fellas House.plan I have kind of got it to work however there is still a gap from the evasion the upper roof line. Any help is greatly appreciated. Thank you. Link to comment Share on other sites More sharing options...
scottharris Posted February 8, 2015 Share Posted February 8, 2015 I modified the roof manually in planview using HD Pro very quickly. If you don't have Pro, for the automatic roof to work, I did these steps: Remove the setting for the walls to extend the roof downward Make the wall thickness is the same as wall 3 and align collinear; set to high shed gable Set wall 3 to high shed gable; and do the same to the wall in the attic; then, for the attic wall align it with the wall below Lower the nook ceiling height ½” – not sure why… Set wall 5 to full gable Link to comment Share on other sites More sharing options...
dgallagher Posted February 10, 2015 Author Share Posted February 10, 2015 Tried those steps and ended up with a roof like what is attached. I am using Home designer suite 2015. When I remove the roof on the nook the walls are doing what they are supposed to. I appreciate your help thus far. Thank you. Fellas House Weird Roof.plan Link to comment Share on other sites More sharing options...
scottharris Posted February 10, 2015 Share Posted February 10, 2015 You are very close! I did two things to your plan: 1. aligned the invisible wall in your nook to the outside of the wall 2. aligned the attic wall with the wall below. and, 3. I noticed a wrinkle in your roof on the opposite side, so I made your ceiling the same height in your entry (it was different by 1/8" than your other rooms). Fellas House Weird Roof-2.plan Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 10, 2015 Share Posted February 10, 2015 Also, you have not built the garage correctly. You need to name it's room type as 'garage', then you need to build>floor>build foundation. Link to comment Share on other sites More sharing options...
dgallagher Posted February 12, 2015 Author Share Posted February 12, 2015 Thank you for your help. Very helpful. Thank you. Link to comment Share on other sites More sharing options...
