How to remove side windows from Box Window
BlueEnergy
I need to draw a box window that is basically a 12" bump out.  That has a raise floor and fits under the existing roof overhangs. So there is no room for side windows inside the box, but HD Pro 2021 still forces them in there.  Also want two windows side by side in the front.
How do you remove the side windows?  See photos.
55 minutes ago, DavidJPotter said:
Click on the Window you wish to edit or delete, then press your "Tab" key or "Next" icon to then select only the intended window, then edit or delete as you wish.
I wish it was that easy.  I believe the Box Window tool has a defect, where the side windows can't be removed.  As the photos show even when the window size of 0" wide it still leaves them in place.  If any can verify it is working for them and what version that would be helpful.
