Floor Edge Line Weight
ChiefJeet
I wish to change the edge line weight of ground floor slab visible in the elevation. Normally I would switch to the elevation, find out the layer of the object and change the line weight in the Display Options. When I select the slab in the elevation, its layer is given as Rooms and I change the line weight in the Display Options to 150 and it has no effect on the thickness of the layer. If I open up the room spec and edit the floor structure, there is no option to change the line weight there. Please advise if there is a solution for this. I have attached the plan file and the video. Thanks in advance.
AAPlan1.plan
Thanks Eric . I have tried changing the line weight of Walls, Foundation and it does not have any effect on the slab line. I have not created a foundation plan and there are no foundation walls. If I open the room specification and on structure, only the floor slab is shown. Please see the plan attached in the earlier post.
