XxAmandaxX Posted July 4, 2020 Share Posted July 4, 2020 I'm sorry if this has already been asked. Every time I try to search for this topic I can't ever find anything about it. How do we get the built-in refrigerators to place inside the cabinet? I can't ever get it to work. If I recall correctly, when I used Home Designer Suite 2018 I was able to get them to place, but since I've been using Home Designer Pro 2020 I can't ever place them. Link to comment Share on other sites More sharing options...
solver Posted July 4, 2020 Share Posted July 4, 2020 Create an open front cabinet, insert the refrigerator manually. Link to comment Share on other sites More sharing options...
XxAmandaxX Posted July 4, 2020 Author Share Posted July 4, 2020 On 7/4/2020 at 5:02 AM, solver said: Create an open front cabinet, insert the refrigerator manually. Expand Yes, this is what I did end up doing. I really thought in Home Designer Suite I just had to click on the cabinet and it placed it inside, am I wrong? Either way, thank you so much for taking the time to reply and help me out! Link to comment Share on other sites More sharing options...
LawB10 Posted July 4, 2020 Share Posted July 4, 2020 Keep in mind that you have to use a full height cabinet and it has to bigger than the refrigerator. Be aware of the two types, the Built in and the stand alone, Built in will place in the cabinet, stand alone will not. Link to comment Share on other sites More sharing options...
4ndrew Posted August 23, 2020 Share Posted August 23, 2020 On 7/4/2020 at 5:02 AM, solver said: Create an open front cabinet, insert the refrigerator manually. Expand Hi Eric - how did you get rid of the bottom? I can remove the kick, but still have a bottom panel on my otherwise open cabinet. Link to comment Share on other sites More sharing options...
solver Posted August 23, 2020 Share Posted August 23, 2020 On 8/23/2020 at 1:33 PM, 4ndrew said: how did you get rid of the bottom? Expand Select it and delete it. Link to comment Share on other sites More sharing options...
4ndrew Posted August 23, 2020 Share Posted August 23, 2020 On 8/23/2020 at 2:56 PM, solver said: Select it and delete it. Expand Hi Eric - thanks, but I have no idea where/how to select parts of cabinets in a way that lets me delete them; when the object is open, I only see an option to select a face item. Link to comment Share on other sites More sharing options...
solver Posted August 23, 2020 Share Posted August 23, 2020 Click the part in the 3D display on the right. Or in the list of items. Link to comment Share on other sites More sharing options...
4ndrew Posted August 23, 2020 Share Posted August 23, 2020 On 8/23/2020 at 3:22 PM, solver said: Click the part in the 3D display on the right. Or in the list of items. Expand That's what I thought - but I'm unable to select from either. Here's what I'm seeing. Is this maybe not available in HD Pro? Link to comment Share on other sites More sharing options...
solver Posted August 23, 2020 Share Posted August 23, 2020 Go to Front, not Materials. Link to comment Share on other sites More sharing options...
4ndrew Posted August 23, 2020 Share Posted August 23, 2020 Sorry, that's just where I was in the menu. Here's the Front page... nothing listed to delete? Link to comment Share on other sites More sharing options...
solver Posted August 23, 2020 Share Posted August 23, 2020 When you get the cabinet made, save it in the Library Watch on YouTube: http://youtu.be/7-h7ahl_jPc?hd=1 1 Link to comment Share on other sites More sharing options...
4ndrew Posted August 23, 2020 Share Posted August 23, 2020 Thanks - lunch... lol. ...wow, that is not easy. It works in a few other combinations (I think) but there isn't a clear reason for why it works. Per your comment - this feature could definitely use some attention. FWIW in one method I couldn't click the face of the bottom "separation" - only via the list. Link to comment Share on other sites More sharing options...
solver Posted August 23, 2020 Share Posted August 23, 2020 Keep in mind that you can easily build simple cabinets like this from parts -- partitions, shelves, custom countertops, slabs etc. This is a Custom Countertop with a molding for the sides. 1 Link to comment Share on other sites More sharing options...
