Chiefuserandrea Posted July 3, 2020 Share Posted July 3, 2020 Hi there, I’m using home designer pro 2021. Could someone please help me build this roof? When I use build roof tool, the roof comes out almost spot on, except for the outdoor entertainment area, and the two narrow patios. Any help would be greatly appreciated!! Many thanks in advance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 3, 2020 Share Posted July 3, 2020 Please post a copy of your plan for others to look at and study in order to help you. That roof system should be easy to create using railing walls to surround the entertainment area, You set the railing walls to display "Post and Beam" to hold up the roof and turn off the balusters and rails. DJP Link to comment Share on other sites More sharing options...
Chiefuserandrea Posted July 3, 2020 Author Share Posted July 3, 2020 Many thanks David, I have attached my plan. It’s not working so I think I’ve done something wrong... thanks again Link to comment Share on other sites More sharing options...
solver Posted July 3, 2020 Share Posted July 3, 2020 12 minutes ago, Chiefuserandrea said: I have attached my plan. We need the plan file, not a picture of the plan Close Pro first before attaching. Try this first. Make sure this is checked for the rooms with no roof, and if they are not rooms, they need to be, so do like David said. Link to comment Share on other sites More sharing options...
Chiefuserandrea Posted July 3, 2020 Author Share Posted July 3, 2020 Thanks so much for your fast reply, I have attached the file. Ok, I will try that also. I am new to the program, so I need all the help I can get lol. Many thanks HILLS_DEFAULT.plan Link to comment Share on other sites More sharing options...
solver Posted July 3, 2020 Share Posted July 3, 2020 See image above. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 3, 2020 Share Posted July 3, 2020 DJP Link to comment Share on other sites More sharing options...
Chiefuserandrea Posted July 3, 2020 Author Share Posted July 3, 2020 David, you are amazing!!! Thank you so much for helping me fix all those weird mistakes! The roof is almost perfect. Attached is the builders plan. As you can see, the veranda and deck have a flat piece as part of the roof... the roof extends to this point and then flattens out around the veranda. Thank you so much for putting the time into that video!! Link to comment Share on other sites More sharing options...
Chiefuserandrea Posted July 3, 2020 Author Share Posted July 3, 2020 The areas makes with green..... im so confused!! thanks so much again Link to comment Share on other sites More sharing options...
solver Posted July 3, 2020 Share Posted July 3, 2020 Do you have elevations or a 3D view you could show us? Cannot tell from a plan view what that part of the roof looks like. Link to comment Share on other sites More sharing options...
Chiefuserandrea Posted July 3, 2020 Author Share Posted July 3, 2020 Ok I will ask the builder. Thank you so much for all your help so far!!! I will post once I get the reply. many thanks, Andrea Link to comment Share on other sites More sharing options...
Chiefuserandrea Posted July 3, 2020 Author Share Posted July 3, 2020 I think it might be something like this... Link to comment Share on other sites More sharing options...
