glass block issue...
rferraro
How can I stop the framing floor members from displaying when using a glass block wall?
I'm building a glass block shower, and when a wall type is changed to glass block, the floor framing shows through. How can I prevent this?
Thanks!
Were I you, I would use a glass wall for the shower walls. Change the material for a glass wall from glass to glass block. Also change the thickness of the glass wall to the thickness of Glass block. Then using the Tri Color icon (Adjust Material properties tool) adjust the "Transparency" property of glass block to suit or emulate your actual glass block.
