rferraro Posted June 27, 2020 Share Posted June 27, 2020 How can I stop the framing floor members from displaying when using a glass block wall? I'm building a glass block shower, and when a wall type is changed to glass block, the floor framing shows through. How can I prevent this? Thanks! Link to comment Share on other sites More sharing options...
solver Posted June 27, 2020 Share Posted June 27, 2020 1 minute ago, rferraro said: the floor framing shows through. Could you post a picture? Link to comment Share on other sites More sharing options...
rferraro Posted June 27, 2020 Author Share Posted June 27, 2020 Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 27, 2020 Share Posted June 27, 2020 Were I you, I would use a glass wall for the shower walls. Change the material for a glass wall from glass to glass block. Also change the thickness of the glass wall to the thickness of Glass block. Then using the Tri Color icon (Adjust Material properties tool) adjust the "Transparency" property of glass block to suit or emulate your actual glass block. DJP Link to comment Share on other sites More sharing options...
solver Posted June 27, 2020 Share Posted June 27, 2020 What David said, and here is why. Link to comment Share on other sites More sharing options...
rferraro Posted June 27, 2020 Author Share Posted June 27, 2020 Thanks David, that worked Funny to have to do all of that, you'd think the glass block wall would offer an option to prevent the floor framing from showing. But it's working fine now... Link to comment Share on other sites More sharing options...
rferraro Posted June 27, 2020 Author Share Posted June 27, 2020 Thanks Solver -- it makes more sense now. Link to comment Share on other sites More sharing options...
solver Posted June 27, 2020 Share Posted June 27, 2020 7 minutes ago, rferraro said: Funny to have to do all of that Chief Premier has a checkbox to make any wall a Partition Wall. Another option is to use a Pony Wall. Make the lower wall 1" tall and assign a material of your choice. Link to comment Share on other sites More sharing options...
