azdesigner Posted May 18, 2020 Share Posted May 18, 2020 I can't find a help topic to show me how to do a small roof over a box window, like in the photo attached. Does anyone know of an article or video that would explain this? (I'm trying to do it over a bumpout, not a true box window.) Thanks. Helena Home Designer Architectural 2021 Phoenix Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 18, 2020 Share Posted May 18, 2020 You will not be able to duplicate that roof using Architectural at all. You will have to be happy with three hip roof planes with only an auto-generated roof (this is true in Suite and Architectural but NOT in Home Designer Pro). In Architectural you can manually draw the three walls of the Architectural feature or use the box bay window tool but neither Suite or Architectural is capable of curved roof planes.You might be able to find such a roof symbol at 3D Warehouse that you can import and apply to your plan that looks like the roof planes in the photo, on that you will just have to look and see. DJP Link to comment Share on other sites More sharing options...
solver Posted May 18, 2020 Share Posted May 18, 2020 Search the library for flared awning. Try the Bonus Catalogs too. Link to comment Share on other sites More sharing options...
Darkhorse41 Posted May 19, 2020 Share Posted May 19, 2020 I created one in 3D software that I have. It will import into the plan and you can scale it to the size you want. I have to create a lot of custom objects so let me know if you need anything. I have included the file and it is 3ds. I have found that this file type works best with curves or flared objects. Thanks roof flared.3dsFetching info... 1 Link to comment Share on other sites More sharing options...
azdesigner Posted May 19, 2020 Author Share Posted May 19, 2020 Thanks for your help, everyone. Just wondering, can I reply to a specific comment, or does it all go in the main thread? DavidJPotter, is there a video that shows how to do what you describe? Darkhorse 41, thank you for sharing that download. Any tips for applying it to the bumpout? How would I remove the auto-generated roof for the bumpout so that I can install the roof? Link to comment Share on other sites More sharing options...
Darkhorse41 Posted May 19, 2020 Share Posted May 19, 2020 Here is a quick view of a bump out with the flared roof applied. 1 Link to comment Share on other sites More sharing options...
azdesigner Posted May 19, 2020 Author Share Posted May 19, 2020 Darkhorse41, thanks so much for your help. 1 Link to comment Share on other sites More sharing options...
