Syd1953 Posted February 25, 2020 Share Posted February 25, 2020 I am new to this so bear with me please. I am trying to change from 24" to 16" OC in the "define wall" dialogue. When I highlight the 24" OC box and click on it all I get is a picture of a teapot. I have been working on this for over an hour and am getting pretty frustrated. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 25, 2020 Share Posted February 25, 2020 What program are you using? If you are seeing the teapot, you are only picking the "pattern", and not the "material". Go the wall again and pick the material and a drop box should show where you can pick your framing. Or even try your owner's manual on the help tab. That is probably the best place to start with any questions so you don't have to wait for someone to reply. Link to comment Share on other sites More sharing options...
Syd1953 Posted February 25, 2020 Author Share Posted February 25, 2020 I'm using the Architectural version. When I click on the materials box I get a picture of the GD teapot, not a drop down menu of wall types as in the training videos. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 25, 2020 Share Posted February 25, 2020 That may be an issue with Architectural then. I haven't used that one for a few years, so I forget what it can and can't do. Depending on what type or how much you use it, you may want to consider upgrading to Pro. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 25, 2020 Share Posted February 25, 2020 You should be seeing these dialog boxes. You would then choose 16" oc from the library drop down, that also shows. Link to comment Share on other sites More sharing options...
solver Posted February 25, 2020 Share Posted February 25, 2020 Be aware the videos show Pro which has many features the other titles do not. You can change the basic structure -- ceilings, floors, walls etc in Pro, but not in Architectural. Link to comment Share on other sites More sharing options...
Syd1953 Posted February 25, 2020 Author Share Posted February 25, 2020 I'm too embarrassed to say what I wasn't doing but I got it. Thanks for all the help and I will turn on signature display. I will be back I'm sure. Link to comment Share on other sites More sharing options...
