Wall ghost with Roof Cuts Wall at Bottom
solver
The way that command is programmed "Roof Cuts Wall at Bottom" the wall needs to be 'on top" of a roof plane to work properly. To do otherwise is to use the software in an unintended way (so you get unintended results when you do so).
If you program a wall to be cut by a roof plane at its bottom, you make sure that the wall in question is on top or within the area of a roof plane only. That is the only purpose of that command.
