CoachRob14 Posted April 8, 2019 Share Posted April 8, 2019 Good Morning Everyone, I have a ranch style home- 2 car front facing garage and a deck that is 17' x 8". Floor 1 height is set at "0". When entering the house from the back of the garage, I walk up three 6" steps. Therefore, I want to set the Garage Floor height at -18", to create this level separation. Each time I change the garage height to -18", I click back on the living level, and it changed with the garage to -18". Each time I try and change the living plan back to 0", the garage changes back to 0" with it. DOES ANYONE KNOW WHY I AM UNABLE TO KEEP THESE AT 2 SEPARATE HEIGHTS? Home_Designer_Suite_2019_4_8_2019_8_08_49_AM.mp4 Link to comment Share on other sites More sharing options...
Rookie65 Posted April 8, 2019 Share Posted April 8, 2019 Do you have "rebuild walls/floors/ceilings" checked? Or rebuild foundation checked? What are your garage default settings? Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 Sent a picture of the garage settings. Where do I find out if I have that option checked? If I checked it somewhere, I would like to uncheck it. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 8, 2019 Share Posted April 8, 2019 Go to your default settings under edit. Look at foundation and framing. See if "automatically rebuild" for foundations is checked. There you can also set your default for the garage stem wall which is something you'll want to look at as well. Of course, with Suite I do not know what all of the limitations are on what you can set. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 I went to the settings. I didn't see any options outside of "automatically rebuild foundation" Link to comment Share on other sites More sharing options...
Rookie65 Posted April 8, 2019 Share Posted April 8, 2019 click on automatically build foundations and do not use the monolithic slab. Again, Suite and all of its limitations is not something I am familiar with. You may be able to get better help from someone who has used it. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 Okay... Looks like auto rebuild foundations did the trick! Thank You. I am SO FAR AHEAD of where I was 7-10 days ago, where I couldn't draw stairs or even conceptualize a deck, or raising/lowering floor levels. I think I need to learn to do things in the proper order. Thank you again. Link to comment Share on other sites More sharing options...
Rookie65 Posted April 8, 2019 Share Posted April 8, 2019 Ok, great. Yes, you are making good process. There's a learning curve to this, yet once you learn something, it stays with you. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 I know this is child's play for you all... But for me this is pretty good lol. I have become decent on the interior- can set up a kitchen, cabinets, countertops, furniture, etc... NOW- I need to take the final dreaded step- start getting into TERRAIN (which scares me lol) Link to comment Share on other sites More sharing options...
Rookie65 Posted April 8, 2019 Share Posted April 8, 2019 Terrain can be tricky, yet think logically with it. Keep in mind it's initially based on the height BELOW the first floor. Keep in mind the garage floor level too when you set it. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 Luckily, this house I am working on currently has a flat yard all the way across. Here is how smart I am so far- I have a driveway that is now covered in grass- and the grass covered my deck as well. smh- cant wait to figure this one out lol Link to comment Share on other sites More sharing options...
Rookie65 Posted April 8, 2019 Share Posted April 8, 2019 Well, you have a main floor at 0. What is the depth of the floor framing? Then, how far below is the garage floor? That is what your setting ought to be, plus about an inch so the garage floor is above the grade. Keep in mind the driveway should be above the grade to be visible. So when you add the driveway, make it 1/2" or so and set the depth to a couple of inches. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 How does the program not understand I want a driveway here, not grass? lol I don't understand it. Home_Designer_Suite_2019_4_8_2019_10_39_58_AM.mp4 Link to comment Share on other sites More sharing options...
solver Posted April 8, 2019 Share Posted April 8, 2019 Think about the relationship of the garage floor, driveway and terrain. The driveway should be a bit lower than the garage floor, and the terrain should be a bit lower than the driveway. If your model needs to be different, then you will need to do some things differently. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 I understand fully what you are saying. Floor is 0". Garage is -18" Therefore, in order for the driveway to show, grass level has to be below 18". I just don't know how to isolate just that space of grass to accomplish that.. Will keep trying. Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 meaning... Do I use an elevation point? an elevation line? an elevation region? something else that Suite doesn't possess? Link to comment Share on other sites More sharing options...
solver Posted April 8, 2019 Share Posted April 8, 2019 2 hours ago, CoachRob14 said: Luckily, this house I am working on currently has a flat yard all the way across. 11 minutes ago, CoachRob14 said: I just don't know how to isolate just that space of grass to accomplish that.. Will keep trying. The simple solution is to drop the terrain -- is there something wrong with doing that? Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 Is this what you are referring to? "Subfloor height above terrain"? Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 There is no way that what I just did is legit... I just went to "create a rectangular feature"- drew a driveway rectangle- changed the material to asphalt...it LOOKS like a driveway- No way this can be correct, can it? Link to comment Share on other sites More sharing options...
LawB10 Posted April 8, 2019 Share Posted April 8, 2019 upload your plan, please... Link to comment Share on other sites More sharing options...
CoachRob14 Posted April 8, 2019 Author Share Posted April 8, 2019 Hey Guys, Just got in from Track Practice. So...I went ahead and took some actual pictures of the house I am trying to replicate... and then some pictures of where I currently am. I am pretty pumped up to be honest- probably amateur hour for you all, but for me, it is a major accomplishment to have as much done as I currently do have, since i have only been messing with Exteriors for about a week. Would love to hear any and all thoughts! 3 hours ago, LawB10 said: upload your plan, please... Quinnipiac.plan Link to comment Share on other sites More sharing options...
