rfcomm2k Posted February 28, 2019 Share Posted February 28, 2019 Can the boundary for a fixture be turned off? Example, I want to place a tub closer to a toilet than code allows. The software has set a minimum distance that another object can be placed next to a toilet (around 7" if I measured correctly). I need to over ride that in my design (do not worry all you code addicts, it is for a RV, not a permanent residence) Link to comment Share on other sites More sharing options...
solver Posted February 28, 2019 Share Posted February 28, 2019 10 minutes ago, rfcomm2k said: Can the boundary for a fixture be turned off? No Link to comment Share on other sites More sharing options...
rfcomm2k Posted February 28, 2019 Author Share Posted February 28, 2019 Quote Thanx Link to comment Share on other sites More sharing options...
LawB10 Posted February 28, 2019 Share Posted February 28, 2019 Hold down the Control key and place the fixture where you want it. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 28, 2019 Share Posted February 28, 2019 Or you can select the item, click "transform/replicate" and then move the object the desired distance along the axis it needs to be moved on. Link to comment Share on other sites More sharing options...
solver Posted March 1, 2019 Share Posted March 1, 2019 I would not recommend using Control to override movement as it's completely free movement. Better to use one of the precision movement tools. Watch on YouTube: http://youtu.be/yR00vywYtNY?hd=1 1 Link to comment Share on other sites More sharing options...
rfcomm2k Posted March 1, 2019 Author Share Posted March 1, 2019 Thanx to LawB10, Rookie65, and Solver. That is exactly what I needed. I wanted to override the limitation by placing the toilet 3" closer to the tub in a tiny house I am designing (and actually started to build already). Time has come to start getting fixtures placed and daughter decided she wanted a different tub than she originally chose, and of course the new tub is 5" longer than the original. Link to comment Share on other sites More sharing options...
