jwbassgarl 0 Posted November 24, 2018 (edited) Hello all. I need some help modeling my roof. I have added a second floor over the garage but It created a double roof. See the attachment. I am trying to create a single roof over the whole house but everything I've tried does not work (rebuilt roofs & roof planes, changed 2nd floor height, reset plan to defaults - done all of these numerous times). I've searched the forum but could not find anything that would help. Any ideas how I can eliminate the the lower roof? I'm using HD pro 2019 build 20.3.0.54x64. Edited November 24, 2018 by jwbassgarl Left out HDP info Share this post Link to post Share on other sites
solver 628 Posted November 24, 2018 I see you said Pro, but ... You can help everyone by adding this info to your signature (see below for how to turn them on, then see mine for an example) by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and keeps others from having to hunt for it. And, turn on signature display too. ---- Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Share this post Link to post Share on other sites
solver 628 Posted November 24, 2018 It's not clear just what you want to do, but I'll take a guess. Check Ignore Top Floor in the build roof dialog. Share this post Link to post Share on other sites
jwbassgarl 0 Posted November 24, 2018 Hi, and thanks for the tip on signatures. I did check ignore top floor but then the upper floor will not show in Doll House view, just Perspective Full Overview. Share this post Link to post Share on other sites
jwbassgarl 0 Posted November 24, 2018 What I am trying to do is slope the top floor roof all the way down to encompass the 1st floor. I don't want a double roof. Share this post Link to post Share on other sites
solver 628 Posted November 24, 2018 16 minutes ago, jwbassgarl said: but then the upper floor will not show in Doll House view, There are 2 ways around this. 1) Turn off the display of roof planes. (Layer Display Options). 2) Turn off Auto Rebuild Roofs, select all the roof planes and click the Display On Floor Above icon in the Edit Toolbar. Share this post Link to post Share on other sites
jwbassgarl 0 Posted November 24, 2018 I've got the roof planes selected but can't seem to find the Display On Floor Above icon. Share this post Link to post Share on other sites
solver 628 Posted November 24, 2018 My edit toolbar has been moved -- yours is probably still at the bottom left. If you right click the center selection handle, you get the same items that are in the edit toolbar. Share this post Link to post Share on other sites
jwbassgarl 0 Posted November 24, 2018 OK, got all roof planes moved to upper floor but this did not get rid of the double roof view I get in Perspective Full Overview. I am open to further suggestions. Share this post Link to post Share on other sites
LawB10 10 Posted November 24, 2018 Upload the plan please..... Share this post Link to post Share on other sites
jwbassgarl 0 Posted November 24, 2018 Plan was over 25MB - had to zip it. See attached. Aprils (Tricia) House 1-REVERSED 2 with 2nd Floor.zip Share this post Link to post Share on other sites
solver 628 Posted November 24, 2018 After you build the roof with Ignore Top Floor, does it look correct? If so, then move the roof planes up. Share this post Link to post Share on other sites
jwbassgarl 0 Posted November 24, 2018 That was the secret! All views look correct now. Thank you so much Solver. Share this post Link to post Share on other sites
LawB10 10 Posted November 26, 2018 Uncheck ignore 2nd floor and lower the ceiling heights to 0" on the second floor, delete the bumpout and make that wall one complete wall (stairwell) change the interior walls to exterior walls. On the first floor change the Garage ceiling heights to its defaults. Go to the catalogs and click Architectural>windows>rounded>quarter, click and install, then change to broken Arch and change the arch height. Now uncheck auto rebuild roofs and check default ceiling heights for the second floor, use the full camera to see what happens. Share this post Link to post Share on other sites
