frameless shower door for bath tub
Donco15
Hi everyone,
I have created a drop in bath tub and want to create a frameless shower door
I followed the tutorial on creating the drop in tub and now have difficulty getting a frameless shower door to be placed on the deck that was built to house the drop in tub.
Any help would be most appreciated
Note:  I tried using a half wall and it would not work.. I tried using a full wall and it did not work
I need the glass door to sit on top of the surround
Thanks
D-
  • 1 year later...
  • 2 weeks later...
You merely create a custom slab, then cut a hole in that custom slab sized to fit a tub into it from your Library Browser. Then place the tub symbol into the hole (the slab needs to be the right height and length to properly display the tub symbol. This is Easy to do, try it!
  • 5 years later...
I recently installed a frameless shower door from Aston over my drop-in tub, and it turned out great. The glass looks sleek, and the quality is solid. One thing to keep in mind: ensure your walls are plumb and level before installation. Frameless doors require precise alignment to function properly. Also, regular maintenance like wiping down the glass after each use helps keep it clear and spot-free.
