Library Browser Blank
JeriRay
Why do I get blank on Library Browser?  (any item not shown)
My version is Home Designer Pro 2017.  Catalogs are downloaded successfully and updated but not shown on the panes.  Filters are clear.  I check file management folders are correct.  I download some user catalogs and imported library.  The message for example reads "34 items have been imported".  When I searched a door for example, a pointer over a button to stop search, a little message shows "Your search returned 427 results".  It's still empty.
I think it was my first time to use Library Browser since installation or upgrade to Pro.
Thank you for your help.
Mike
The left panel was swept to the left edge since I was puzzled why the video showed three panels, not two panels.  When I took Library Browser out, I saw double vertical line on the left and then swiped it right.  Bingo.
I wish I wrote that two panels shown in the first thing.
Thank you so much!
  • 6 years later...
Thank you,
David, your video assured me everything was set up right.
JeriRay, your last comment caused me to look at it a little bit differently I just had to drag the bottom line of the window down it was odd.
