blackbeard Posted May 5, 2018 Share Posted May 5, 2018 Using HDA v18, build 18.3.2.2X64. My fireplace does not display correctly in any view. See images full camera front, elevation 1 side; and elevation 2 front. In all three, the fireplace appears to be dropped down below the first floor level. But when I check the fireplace dialog box, last image, the Floor to Bottom value is set to 0. Further, if one looks closely at the three images, you will notice the guidelines are all at proper position based on the dialog box. I have closed and reopened the application. I have restarted my computer. Nothing seems to fix the display problem. Other than going through the hassle of re-installing my product, is there anything else I might try first. Thank you. Kevin Home Designer Version 18; 64 bit Link to comment Share on other sites More sharing options...
solver Posted May 5, 2018 Share Posted May 5, 2018 Posting your plan file (just like you did the images) will give others something to work with. Link to comment Share on other sites More sharing options...
blackbeard Posted May 5, 2018 Author Share Posted May 5, 2018 I do apologize for leaving the word architect out of my signature line notwithstanding the first sentence implied that.. The built in help system didn't help. Nor did Knowledge Base or anything else for that matter. My graphics card Nvidia GTX1050 has the latest driver as well. So, any suggestions. Blackbeard Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 5, 2018 Share Posted May 5, 2018 I suggest that you delete the offending fireplace object and try another one. The behavior the current one is displaying is corrupt and incorrect. Try another one. DJP Link to comment Share on other sites More sharing options...
blackbeard Posted May 6, 2018 Author Share Posted May 6, 2018 I can do that. Just build my own. What are soffits and partitions for anyway. :-) Many, many thanks. blackbeard Link to comment Share on other sites More sharing options...
