rosiebeauginger Posted April 16, 2018 Share Posted April 16, 2018 The exterior elevation of the home has stucco trim/pop-out with stone façade below. Please see attached picture. I made the horizontal trim with a soffit and bullnose molding. I'm stumped on how to make the vertical trim that should run down the left side of the stone. I would appreciate suggestions. Thank you. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 16, 2018 Share Posted April 16, 2018 What have you tried that did not work? I should think that another soffit would do, if you had Chief Premier you would have several more choices and tools for that. DJP Link to comment Share on other sites More sharing options...
solver Posted April 16, 2018 Share Posted April 16, 2018 Can you post an image of "the vertical trim that should run down the left side of the stone"? Link to comment Share on other sites More sharing options...
rosiebeauginger Posted April 16, 2018 Author Share Posted April 16, 2018 When I attach a soffit to the left of stone, the soffit runs the correct direction but the bull nose molding does not turn vertical. I have tried changing the measurement of the molding but that causes it to stick too far from the wall. It seems like I need 3 dimensions for the molding, but there are only 2. I have attached a picture of my objective and my problem. Thank you. Link to comment Share on other sites More sharing options...
solver Posted April 16, 2018 Share Posted April 16, 2018 Search the library for shapes. You will find cylinders. try using one of the vertical ones, and combine with a soffit, so the cylinder is on the outside and the soffit is against the house. Link to comment Share on other sites More sharing options...
rosiebeauginger Posted April 16, 2018 Author Share Posted April 16, 2018 Success! Thank you Link to comment Share on other sites More sharing options...
