rosiebeauginger
Vertical elevation trim
The exterior elevation of the home has stucco trim/pop-out with stone façade below.  Please see attached picture.  I made the horizontal trim with a soffit and bullnose molding.  I'm stumped on how to make the vertical trim that should run down the left side of the stone.  I would appreciate suggestions.  Thank you.
What have you tried that did not work? I should think that another soffit would do, if you had Chief Premier you would have several more choices and tools for that.
Can you post an image of "the vertical trim that should run down the left side of the stone"?
When I attach a soffit to the left of stone, the soffit runs the correct direction but the bull nose molding does not turn vertical.  I have tried changing the measurement of the molding but that causes it to stick too far from the wall.  It seems like I need 3 dimensions for the molding, but there are only 2.  I have attached a picture of my objective and my problem.  Thank you.
Search the library for shapes. You will find cylinders. try using one of the vertical ones, and combine with a soffit, so the cylinder is on the outside and the soffit is against the house.
