Issues with Render in 2019
PCWdesignbuild
Is anyone else having issues with the rendering in 2019.  I can get a good render, but absolutely cannot get shadows.  I can get reflections to work, only with Enhanced Lighting on, but with that on, the entire render is off.  If anyone has the magic key, I'd love to know!  My video card meets system requirements.
  On 3/10/2018 at 3:15 AM, alfrosen6 said:
Yes. I have the same problem.  I have submitted the issue to technical support.
Expand
Weird!  I'm glad I'm not alone, though.  Hopefully there's just a setting we're missing - otherwise it's going to be very frustrating trying to get realistic renders to clients!  I also submitted a tech support ticket yesterday but haven't heard back, yet.
If this is the best they can do, I want my money back.  I could not find any information in the help documentation specifically on Pro 2019 features.  It would be interesting to see if we both get the same responses from technical support.
Good luck!
I agree.  There seems to be no support or troubleshooting for 2019 yet and when I read through the accompanying documents, some of the menu items weren't even addressed.  I haven't gotten a response yet, but hopefully will, soon!  I owe renderings to clients this week!
Keep in mind that the latest version has only been out for a few days. That does not mean that other particular users who helped develop these versions cannot help (I have helped develop all versions of Home Designer and Chief Architect Premier since 1999) are not here to help and also the Tech Support and Software Architects and Engineers at Chief Arachitec Inc are also there to communicate with.
I can get usable renders in Home Designer titles as well as Chief Architect Premier presently. It is a matter of finding the right settings, adjusting material and lighting settings, this has not changed since 1999.
You are each free to have your own opinions and to make your own decisions as it should be. I currently do not use "Physically Based Rendering" except on a trial and error basis. This rendering technique is brand new with this release and is not as refined now as it will be later. For now, I recommend just using the "Standard" rendering technique which has not been added to or changed; it still works the same way as it did in older versions.
Hi David,
I appreciate your input - I love the program, but if this issue continues, I'd prefer to go back to my previous version.  The other user and I both have issue tickets in with Tech Support and are awaiting help.
You're able to get renderings in Home Designer Pro 2019 without issue?  The settings have indeed changed quite a bit, seemingly - I'm a long time Home Designer user, with a tech background, but am completely stymied as to how to make this thing work properly.  It's never given me shadows, even when restored to default, or adjusting lighting, sun, or any other option.  If you know the proper adjustments, perhaps you could share so I could try them on my end?
Thanks!
I was requested to provide screen shots by Anne Smith, the tech assigned to my case.  She also had me provide her with message logs, the plan file.  Right now all I can really say is that there seems to be no Pro 2019 feature specific help documentation.  I too have used Designer Pro through several version upgrades.  All, except this one have been improvements. The enhanced lighting feature seems to a part of the issue.   Also by disabling enhanced lighting, I get a rendering very similar to that of Pro 2018, except there is still no shadowing, nor are there any reflections.  The Pro 2019 renderings are very dark when using the default ambient lighting setting.  I have to turn up ambient light to maximum to get a rendering that is  marginally usable.
I am waiting on response from tech support.
David,
Thank you for your response.  I think i'll continue to use Pro 2018 for a while until Pro 2019 has its kinks worked out. I am confident that Chief Architect's Home Designer is the best software available to the DIYer like myself.
Al Rosendale
David - thanks for your candor.  It's very appreciated.
I went back to the Home Designer website and looked at their promotional materials for 2019 - it shows beautiful renderings like we've gotten before in previous versions, so it would seem that someone is able to use the program effectively?  Or this is false advertising?
I'm eager to move forward with 2019, but this is really cramping my productivity!
Expand
This is exactly what I'm experiencing.  I have a tech on my trouble ticket but don't have communication from him, yet.
I think the issue is with the enhanced lighting, as well = with it on, everything is dark and unstructured.  With it off, I get a fairly good rendering, but absolutely no shadows or reflections.  Fingers crossed for a fix!
This is the response I have gotten from tech support:
Thank you for the additional information. I took a look at your plan file in version 2019 but was unable to reproduce any problems that you describe - the lighting and shadows look correct without making any adjustments to the ambient light.
Your Message Log file indicates that your computer has an AMD Radeon HD 7660D graphics card, though, and my thought is that this may be the cause of the problem. This is an older graphics card that is no longer supported by AMD, and although you do have the latest drivers, they are over 2 1/2 years old. AMD does offer a 'beta' driver dated 2/29/2016, so you might consider downloading and installing it:
https://support.amd.com/en-us/download/desktop/legacy?product=legacy3&os=Windows 10 - 64
If this doesn't help, though, I'm afraid that your graphics card isn't going to be able to handle the updated lighting in version 2019.
I hope that this information is helpful.
So, this is the response I got from tech support. Before I purchase a new graphics card, I want to see if how many others are having after upgrading to Pro 2019.  David, based on your candid response and what I am getting from tech support, I am very interested to see what happens over the coming weeks.
The video card on my laptop is just a year old, the video card on my desktop is about five years old but both are still supported actively by NVIDIA. There have been some complaints relative to Ray Tracing in X10 (HD Pro's Big brother to Home Designer Pro 2019) but nothing really serious, I have had no trouble gaining professional grade images in Pro 2019 or X10, nor have I heard anything like your complaint at Chief Talk but also as I earlier said, the new Home Designer titles have only been on sale for a few days.
I got the same response - that my video card, while supported, was running on a driver that might be too old.
It's the latest driver for my video card though.  I'm also more than happy to put in a new video card, but I, too, wanted to make sure that doing so would actually fix the problem.
David, you said in a previous post that you and others who worked on the development end were also having issues and complained about the same things we are having issues with.  Are you saying that you can now render with shadows and reflections in Pro 2019?  Could you attach one of your Pro 2019 renderings so I and others can see what quality you're getting?
Thanks!
Same issue here. I have a Core-I7 PC w/ 8Gb ram, and a Radeon HD5700 series 2Gb Radeon video card as well. No shadows can be made to appear in the room camera views. In Perspective Full Overview the camera view is entirely white, except for landscape plants, when "Preferences-> Render->use enhanced lighting" option is checked.
Updated AMD driver to the latest version. Video card is orphaned.
That said, I don't recall having these issues with HD Pro 2016.
My present video card exceeds the minimum requirement as well. I routinely use this same PC to design electronic circuit boards in a 2D and 3D mode, with no issues. The E-CAD software used costs about $12K-15K per seat.
Take a look at CA's video card suggestion recommendations. What is suggested is not an inexpensive upgrade. One shouldn't have to start changing out pcs of expensive PC hardware just to make the $500 CA software work correctly.
Judging from DJP and other's comments, perhaps something is amiss at CA.  Of course, I can use HD Pro as is, but to get the most usefulness out of the software, I would have to start replacing PC components, starting with the video card, etc. Where does it stop? Jeez.
Yes - I'd wager that most of us who utilize this program on a daily basis are running it on some pretty serious machines.  I upgraded from Pro 2017 to Pro 2019 - I never had any issues in 2017, or any of the versions of the software I've used for almost a decade.
I'm not certain that this is a video card issue, actually, because it would seem that certain things could be made to work by "turning off" options which have a heavy drag on our systems.  So far, even with every possible option turned off, I still cannot cast a shadow or get anything other than a fairly flat looking rendering.
The following was posted on the Chief Architect Website:
PBRT & Ray Trace Fixes:
3.19 3D Rendering
• Fixed an issue where the artistic effects of Line Drawing were lessened when Edge
Smoothing on Idle was in use.
• Fixed a problem in the Physically Based Rendering Techniq ue that caused fireplaces to be lit incorrectly on the exterior.
• Fixed some cases where Matte material types would appear to have reflections in the Physically Based Rendering Technique.
• Fixed an issue where materials with a high Roughness value would appear slightly
reflective in the Physically Based Rendering Technique.
• Improved performance of the generation of new 3D views, including previews in the
Library Browser and in dialogs.
• Fixed an issue where fence newel posts could be lit incor
rectly in the Physically Based
• Removed the Opaque Glass option from the Physically Based
• Fixed an issue where louvers on bifold doors in legacy pl
ans would sometimes be lit
incorrectly in the Physically Based Rendering Technique.
• Fixed a problem that someti
mes caused reflective objects
to appear black after being
edited in the Physically Based Rendering Technique.
• Fixed some artifacts that could occur in exterior views w
hen a large terrain was pres-
ent and Improve Light Quality was turned in the Physically Base
• Fixed an issue where setting Hardware Edge Smoothing to “
None” on some Macs
would cause 3D to be incorrect.
• Fixed a problem that caused rooms separated by Room Divid
ers to sometimes be lit
• Fixed an issue that caused Mirror Reflections to be too d
ark when Improve Light Qual-
ity was checked in the Physic
• Fixed a specific case in the Physically Based Rendering T
echnique that caused the view
would become overly bright and washed out.
• Fixed an issue where clicking Reset to Defaults on the Ph
ysically Based panel of the
Rendering Technique Options dialog
could cause the current view
be incorrect.
• Fixed an issue where the Color toggle did not immediately
effect Orthographic views in
some cases.
• Fixed a specific case where Wall Material Regions were no
t lit correctly in the Physi-
6
• Fixed a case where the windo
ws in a Bay/Box/Bow Window co
uld be lit incorrectly in
• Improved rendering when us
ing the Cross Section Slider wh
ile Edge Smoothing on Idle
was turned on.
• Fixed a problem that caused reflections to be incorrect i
n the Physically Based Render-
ing Technique if a Watermark was turned on.
• Fixed a crash that could occur using images of certain si
zes as Ambient Occlusion,
Metal, or Roughness maps.
• Fixed a performance issue involving Ray Casted Shadows th
at occurred while the cam-
era was moving.
• Fixed an issue that caused shadows to be incorrect if onl
y terrain objects were present
in the plan.
• Fixed an issue in which Ray
Casted Shadows did not work c
orrectly when using the
Cross Section Slider.
• Ray Casted Shadows now work
when using the Standard Rende
ring Technique in an
Cross Section/Elevation view.
• Fixed an issue that could cause the Backdrop color used i
n Vector Views to appear
slightly washed out.
• Fixed an issue in which Live Views sent to layout using t
he Vector View Rendering Tech-
nique had line weights that were too thick when printed.
3.20 Ray Tracing
• Low roughness materials will now generate perfect reflect
ions in ray trace views.
• Fixed an issue that could cause artifacts to appear aroun
d lights in ray trace views.
• Fixed an issue that caused ray traces of orthographic vie
ws to be incorrect
So update patches should shortly be forthcoming.
  On 3/16/2018 at 9:07 PM, PCWdesignbuild said:
Installed the update.  No changes.
I was advised to turn off ambient occlusion - I did so.  No change.  My renderings are still the same as they were in the attached photos.
Expand
Turning Off Ambient Occlusion is a fix for AMD Cards and the new PBR Views in Chief , it is a known issue ... it does not help with Standard View AFAIAA , personally I don't like AO anyway so only have it at 15-20% and I think Bloom "softens" the View too much as well..., but the 2019 Titles and X10 seem to need way more "Light" in STD View to make them look good ...about double, so add plenty or turn the one's you have Up....way Up... at least that whatI had to do to the Images below that looked good in X9. The new Sun lux setting seems to have little effect in STD View but in PBR (x10 only 500-2000  works) it is hugely different.
I would say you need to play with your Lighting....and if you haven't added any ? then that is the issue perhaps , you can no longer rely on HD to provide "automatic" lighting and get away with it as even with the Interior Ambient at 50-60% it is not enough on it's own. , then again perhaps the AMD Cards have other Issues too? I use a Nvidia 1070ti now...
Another post on AMD and AO issues....
https://chieftalk.chiefarchitect.com/topic/17322-chief-x10-lousy-camera-views/
Post Your Plan and let Eric or I or DJP have a look at it.....
Also, it's good to have your Forum Signature filled in, especially with the Software Version,
and of course a Name is nice too :) ..............see mine below in Blue for how to do that.
If you don't see my Signature then you have them turned off for the Forum
Toggle it on in UserName>Account >Signatures...... go to the Upper RH Corner of Forum Window.
9.thumb.JPG.a7029221ad46f18d19e2b20f02c8ff0c.JPG10.thumb.JPG.a26310564ccd9e5b1d0fc9dc5b58766d.JPG
I think that the quality of the 3D render was already headed south with the 2018 versions.
Compare these 2 renders:
Left is HDA10 final view with shadows.
Right is HDA2018 with reflections,shadows, and edge smoothing all checked...bloom is unchecked.
In the 2018 version, the lines of the cabinets, appliances, and furniture are all blurred. Doesn't matter if edge smoothing is turned off.  The stool seats have no reflection, either.
Which render would you rather have?
When you upgrade to a newer version from an older version, wouldn't you expect it to be better?
