Kristine Posted February 21, 2018 Share Posted February 21, 2018 Hi all. Trying to replicate the wall in the attached image. Have used both a half wall and a regular full wall though when I abut them it creates a weird angle and assigns a different room to the area where the full wall is (image attached). Am using a shape for the top portion. Is there a better way to go about this? Cheers. Link to comment Share on other sites More sharing options...
solver Posted February 21, 2018 Share Posted February 21, 2018 You must have a wall where the floor covering changes, and should be able to delete it. Post the plan file if that does not fix it. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 21, 2018 Share Posted February 21, 2018 You can emulate walls using a reshaped soffit object (cabinet tools). DJP Link to comment Share on other sites More sharing options...
Kristine Posted February 22, 2018 Author Share Posted February 22, 2018 Thanks Eric. Yes, HD had created an invisible wall (I certainly didn't input it) for some reason. Deleted it and the problem resolved. Still wondering if my method (using a half wall, full wall and shape) was the best way to go about replicating the wall? Cheers. Link to comment Share on other sites More sharing options...
solver Posted February 22, 2018 Share Posted February 22, 2018 None of the Chief Architect/Home Designer products handle that situation. You need a workaround, and yours is one of several that can be used. You mentioned using a shape for the upper part, and I would recommend a soffit as David suggested. Soffits come in with the default drywall (wall) color, and will accept moldings. Here are 2 threads I posted on over at ChiefTalk. Both contain info you might find helpful. https://chieftalk.chiefarchitect.com/topic/16879-stairs-with-drywall-handrails-with-cutouts-in-the-walls/ https://chieftalk.chiefarchitect.com/topic/16668-doorway-flooring-issue/ Link to comment Share on other sites More sharing options...
