johnkapanick Posted August 22, 2017 Share Posted August 22, 2017 How do I figure square footage of entire plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 22, 2017 Share Posted August 22, 2017 If you have Home Designer Pro you could draw a closed polyline around anything and then open the polyline's dialog and see how much it encloses in terms of square feet. Those titles that have the enclosed polyline tool should also work, if what you have does not then your only solution is to upgrade to Pro or Premier. DJP Link to comment Share on other sites More sharing options...
johnkapanick Posted August 22, 2017 Author Share Posted August 22, 2017 thank you!!!! Link to comment Share on other sites More sharing options...
Rookie65 Posted August 22, 2017 Share Posted August 22, 2017 I have found that with Pro 2018, rarely does the sf show on the first floor. Seems to be in the basement and 2nd floor fine though. Link to comment Share on other sites More sharing options...
solver Posted August 22, 2017 Share Posted August 22, 2017 52 minutes ago, Rookie65 said: I have found that with Pro 2018, rarely does the sf show on the first floor. Seems to be in the basement and 2nd floor fine though. Run a Plan Check. That should bring it back. Link to comment Share on other sites More sharing options...
Rookie65 Posted August 22, 2017 Share Posted August 22, 2017 Thank you Eric, it worked. Link to comment Share on other sites More sharing options...
