Changing Line Weights
Paul5280
Using the latest release of HD Pro on a Mac, I'm having problems with the weights of my CAD polylines.  I can modify their color and style but not their weights either individually with Polyline Specifications or in Layer Display Options.  All lines remain default weight.  What setting(s) am I missing?
  • 3 months later...
Well, in order to"SEE" the line weight change on screen you must also turn on "Show Line Weight". Once that is done you can then and only then "see" the line weight change on screen, of course, you can print and see the change but that is an inefficient way to do so, after the fact. That is what the "Show Line Weight" tool is for, take a look (again).
