Acropolis Posted January 5, 2017 Author Share Posted January 5, 2017 this is real interesting, just by selecting each room individually and selecting a roof group that is changing zero to 1, roofs appear on save. show me where that is in the help section on building roofs, its not, and going back to a earlier version it looks like just opening each room, then closing it, puts a roof on it where following directions causes a you to go in circles. Link to comment Share on other sites More sharing options...
Jo_Ann Posted January 5, 2017 Share Posted January 5, 2017 The plan that you uploaded, does NOT have 'roof over this room' checked in any of the rooms. Link to comment Share on other sites More sharing options...
LawB10 Posted January 5, 2017 Share Posted January 5, 2017 Like Jo_Ann stated, all of the rooms 'had no roof over this room' unchecked, also you were using a slab with footings as a roof, was there a reason for that? To change the height of a wall you simply click on the wall and raise it up. If it's a wall within a room, it raise's the room up. You have to click the tools on the toolbar, it's not going to do anything just by hovering the mouse over it. The expectation that you have is difficult to understand..... Link to comment Share on other sites More sharing options...
Acropolis Posted January 5, 2017 Author Share Posted January 5, 2017 let me clarify then because you are working from a week old file, and more important, not paying attention, and too defensive of cumbersome software with many dead end defects. 1. I started fresh plan 2 fresh defaults 3. default was roof over 4. copied over wall structure definitions- the backwards way for home designer, thank you JoAnn so build roofs - does nothing and you go in circles for hours because the inadequacy of the software is it doesn't give any kind of indication. the way the roofs appeared was to go into each room separately, I clicked structure to see everything that was in the defaults was these, and saved, that action alone cause the roofs to start to appear room by room....that in its self is ridiculous as it not in the help section. The problem is - defensive ones, is that the software runs into dead ends, if it doesn't do as expected - the help section doesn't address those error states. so lets move on, I don't need to past the help section for stair cases, I pasted the pic of my software, where is this tool? AUTO STAIR CASE TOOL Stair ways, help section and user manual real clear on what to do to cut the hole for a stair well. followed to a T. it built a stair case exactly in a minute or two, then you spend half a day going in circles Where are the instructions on what to do if it doesn't work? Link to comment Share on other sites More sharing options...
katalyst777 Posted January 23, 2017 Share Posted January 23, 2017 On 1/5/2017 at 2:52 PM, Acropolis said: Where are the instructions on what to do if it doesn't work? Auto Stairwell is an EDIT tool. That means it shows up on the Edit toolbar, or when your right click on a staircase. (Here's a screenshot of what it looks like in Pro.) This Help article has instructions and pay special attention to the "Note" at the end of the article if the edit tool doesn't display when you select the staircase.https://www.homedesignersoftware.com/support/article/KB-00125/creating-a-stairwell-for-your-staircase.html 2 Link to comment Share on other sites More sharing options...
