mitzie Posted August 27, 2016 Share Posted August 27, 2016 I am trying to create modern stair rail such as cable or glass. I cant seem to do it with half walls and such. If I select balusters in fencing it shows as perpendicular to the stairs. How do I create glass or cable railing? I'm using HDA 2014 Link to comment Share on other sites More sharing options...
mitzie Posted August 27, 2016 Author Share Posted August 27, 2016 signature added Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 27, 2016 Share Posted August 27, 2016 Home Designer Pro has the ability to draw stair railings manually (Check " Follow Stairs" on the Rail Style Tab), Architectural does NOT have this ability. Using it you can have any rail style or panels in your LIbrary Browser. DJP Link to comment Share on other sites More sharing options...
LawB10 Posted August 27, 2016 Share Posted August 27, 2016 Using a Half Wall, place it a 1" or so on the stair. Open the specification box and make your changes, to get the glass, change it from solid to panel and then click materials>panel, click select material and change to glass. To get the cable rails you have to use a object from 3d warehouse and then edit the object in Sketchup. Link to comment Share on other sites More sharing options...
Jo_Ann Posted August 27, 2016 Share Posted August 27, 2016 Sloped soffits can also be your friend. https://hometalk.chiefarchitect.com/index.php?/topic/1993-changing-interior-stair-railings-to-panels/ Link to comment Share on other sites More sharing options...
