Cannot move walls in 1" increments
jchenryaia
The best method is to select a wall and then move it by a connected dimension or you can draw a manual dimension and the click on the wall you wish to move accurately and then click on the connected perpendicular dimension. when you click you get an input box where you can enter the desired value.
  On 5/27/2016 at 12:05 AM, jchenryaia said:
Thanks Eric,
I am using Home Designer Essentials.
I have turned the snap button off and I cannot get the walls to move smoothly in small increments still.
I don't see a Home Designer Essentials on the website. Is this an older version?
That's because snaps are off. If your snap grid is set to 1", things will move in 1" increments.
No need to use the control key unless you want to override snaps.
Doing so is usually not a good idea as you will locate items imprecisely.
The dimensions displayed are rounded. Click a dimension to see the actual. It will often end in something like .1296756 instead of .125.
Have you tried opening the copy / move dialogue box and put in the exact dimension you what the selected object to move? You can choose to move the object in the x, y or z axis. I use this quite often.
