Interior Dogear Arch over bar/counter
CEB-HD
Basically wall opening (dining room to kitchen) with half-wall /counter in opening. Top portion of opening drops and angles down on each side (dog-ear).
Living-3.jpg & Kitchen-1.jpg are photos of same.
Thanks!
The simple/easy way is to use solids for the arch area -- the 2 angles and the header above.
See the Wedge shapes in the library, and use a soffit for the header.
Thanks for post the images and for filling out your signature.
I'm assuming you created the dogear arch within the dbx doorway specification option in Pro.
Create the half-wall outside of the doorway.
Open the wall dbx and set it to 'no room definition'.
Hold down the control key, and drag the half wall into the doorway.
Chris,
My apologies because I did not save the the plan, to answer the question Yes.
Put the cabinet inside the doorway and then extend the cabinet overhang to your liking.
The box shape is the one that let's you fill in the gap without being cut off.
