mayall Posted April 28, 2016 Share Posted April 28, 2016 Hi I am in Australia and sizing of framing is generaly 90 x 35mm and 90 x 45mm. i have managed to change most but can not figure out how to change the noggin (blocking) size. I have waided through the framing specifications but can not find this. Link to comment Share on other sites More sharing options...
solver Posted April 28, 2016 Share Posted April 28, 2016 Are you asking about blocking in the wall? Could you post a simple sample plan? Link to comment Share on other sites More sharing options...
mayall Posted April 29, 2016 Author Share Posted April 29, 2016 SOlverYes Blocking in the wall, what we call in Oz Noggin. The timber that is in between the studs aprox half way up. Not sure how to post, could you explain how to. Link to comment Share on other sites More sharing options...
mayall Posted April 29, 2016 Author Share Posted April 29, 2016 Here is a pic of the item i want to change the size of. Link to comment Share on other sites More sharing options...
solver Posted April 29, 2016 Share Posted April 29, 2016 Post a plan just like you posted the picture. Make sure it's not open in Pro. Link to comment Share on other sites More sharing options...
mayall Posted April 29, 2016 Author Share Posted April 29, 2016 Solver please see attached 30 Murphy Street.plan Link to comment Share on other sites More sharing options...
solver Posted April 30, 2016 Share Posted April 30, 2016 I don't see a way of setting this dimension so it will auto build the blocking at a specific size. You can, however, edit the blocking in a 3D framing view. Just select the blocking and open it, or just double click it and its specification dialog will open. Change the thickness to what you need. You can use the Object Eyedropper to copy the change to all the other blocking without having to open each one and make the change. I forget, Pro has the Object Eyedropper, but not the additional tool that lets you select which properties to copy. Looks like this may be a manual process. I'm going to report this as a suggestion to allow the change in the Framing dialog. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 30, 2016 Share Posted April 30, 2016 Whatever you set as wall studs will determine the initial dimensions of the blocking. Once the blocking is added it can be edited to any size you wish by way of each framing members dialog box, one at a time. I had never tired to place wall blocking in Home Designer Pro before today, I have done it many times in Chief Premier but its tools are superior to what you have to painstakingly do in Pro. It can be done however you wish but is entirely a manual effort to do. DJP Link to comment Share on other sites More sharing options...
mayall Posted April 30, 2016 Author Share Posted April 30, 2016 Thanks Guys, for your assistance manual it is. Can not use object eye dropper as it changes the length to the original object. I find they call it "bridging" in the software Link to comment Share on other sites More sharing options...
mayall Posted April 30, 2016 Author Share Posted April 30, 2016 David I set the wall studs to 90 x 35 but the bridging stayed at 90 x 38. Link to comment Share on other sites More sharing options...
justmejerry Posted May 1, 2016 Share Posted May 1, 2016 If Pro has match properties tool you can go in 3D framing overview and click on bridging then click match properties tool and select from the list and it will allow you to change all of it at same time. Link to comment Share on other sites More sharing options...
