lmorris Posted April 8, 2016 Share Posted April 8, 2016 Having trouble figuring out how to incorporate trusses with energy heels. I have raised the roof plane by 12" and at first glance a framing rendering looks fine with the double top plate at the bottom of the truss. After rebuilding wall framing though, there is another small wall built from the top of the main wall to the underside of the top chord of the truss. Looking for any tips to build with energy heel trusses. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 8, 2016 Share Posted April 8, 2016 The proper sequence is to first set all relevant default settings. Then build roofs and check them to make sure your settings are correct. Manually build trusses. Check them in an elevation camera to make sure they are as you want. Then build roof framing, when trusses are in place, the software will build to the trusses. Manually edit any auto framing where it disagrees with what you intend to do. DJP Link to comment Share on other sites More sharing options...
lmorris Posted April 8, 2016 Author Share Posted April 8, 2016 I have followed this sequence and the trusses look fine, as well as the main exterior wall. The item I can't seem to figure out is why the additional stud wall is added on top of the main exterior wall between the double top plate and the underside of the truss top chord. This appears when I rebuild wall framing after the trusses are in place. Is it a result of raising the roof planes to accomodate the energy heel truss? Perhaps there is a default setting I need to adjust?.....I have looked through the settings and don't see anything that seems to apply. I am obviously doing something wrong,,,,,,but don't know what. Thanks Link to comment Share on other sites More sharing options...
solver Posted April 8, 2016 Share Posted April 8, 2016 Please post your plan file. Link to comment Share on other sites More sharing options...
lmorris Posted April 11, 2016 Author Share Posted April 11, 2016 Design-1.planHere's the Plan file Link to comment Share on other sites More sharing options...
lmorris Posted April 11, 2016 Author Share Posted April 11, 2016 Framing Pic! Link to comment Share on other sites More sharing options...
Solution solver Posted April 11, 2016 Solution Share Posted April 11, 2016 Delete all your framing, draw in your trusses. Then build framing. The program is adding a short wall section to support standard roof framing raised 12", which is not needed with a truss. Link to comment Share on other sites More sharing options...
lmorris Posted April 12, 2016 Author Share Posted April 12, 2016 Ahh.....it all makes sense now since I had only drawn one truss as a test. Thanks Link to comment Share on other sites More sharing options...
