Fidellaty Posted March 20, 2016 Share Posted March 20, 2016 Is there any way to see the dimensions of library objects before they are put into a plan? Or should I know how big double sink wide and double sink narrow are? I really thought that v. 2017 offered that, rather than just being able to save a copy to the User Catalog for modification. The very bottom new feature says, "Symbol Object Specification Editable from Library." I misinterpreted that. Link to comment Share on other sites More sharing options...
solver Posted March 20, 2016 Share Posted March 20, 2016 The Library needs improvement. I don't believe there is a way to see without placing in the plan. Some sinks have the width in the description, but many do not. 1 Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted March 20, 2016 Solution Share Posted March 20, 2016 In Architectural after you place a sink it is still resizable, you click on the sink object, hit the tab key to select just the sink object. When it is selected, it will display handles for resizing in terms of width and length. DJP 1 Link to comment Share on other sites More sharing options...
